Guys,
I am closing in on 4000 miles on my '07 2.0T with APR 93/100. Today my "MPH" warning light came on plus a very annoying beeping sound. What the heck does this mean? Car is running perfectly...any ideas??
Thanks
2008 535i - Step - Sport - JB3 1.22 Map 7 - BMS Air Filter - HKS SSQV BOV/Pipe - ERL Aquamist water/meth injection
'07 A4 2.0T, Quartz Grey, 6spd MT, Premium Package, 19" OZ CLASSE 235/35/19
APR 93 & 100 from GermanMotoring K&N Drop-in Filter
Eibach Sportline Springs and Pro-Dampers (2" Drop)
EuroLights Xenon-Charged H7 lowbeams & Yellow ION H11 foglights
1999 VW Passat 1.8T Big Turbo - Garrett T3/T4, Upsolute BT Software, 440cc injctrs, 3" exhaust, +++
Appearance: OEM+
Interior: B6 S4 Recaro Seats
Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
Suspension: Vogtland Coilovers / HSport S4 Sways
Braking: Stoptech 332 BBK
Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
Appearance: OEM+
Appearance: OEM+
~Karl
Appearance: OEM+
~Karl
05.5 B7 A4 longest running with no motor issues at 373whp
Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
APR 93|Greddy FMIC|Carbonio|AWE hpfp|Pulley|TP|SB stg 3 clutch|Ecode 11lbs flywheel|Koni Coils|Hardwired V1|B&B Exhaust|RS4 Sway bar
Jamie | 2008 2.0T FWD 6MT Brilliant Black S-like
S-line Suspension+B5 Spring Perchs | RAI HFC | ER SMIC | 034 TIP | B8 18X8 Sport Wheels | Spacers: 10/12.5mm | RS4 Sway | "D" DV | De-badge | S4 Blackout Grill | Euro RNS-E | OEM Ecode Xenons | Clear Side Markers | Cupra Lip | S4 Mirror Caps | ECS Slotted/Drilled Front Rotors | Ceramic Pads | Poser S-line Door Badges | Podi | 034 Catch Can. Go: Still Stage Zero
B7 RS4
2007 2.0T Q 6MT, S-Line, Ti Package, BB
Revo Stage 2 | JHM Stage 1 Clutch | K&N Drop in | APR HPFP | 034 HFC | AWE Catback | 034 SD Tranny & Motor Mounts | Neuspeed Snub | H&R Sport Springs | Bilsteins | Moog ACA | B5 Perches (removed) | RS4 RSB | ABT Drilled n Slotted Rotors | Redstuff Front & Akebono Rear | Podi Stepper Boost Gauge | Recaro's | H&R Spacers 15f/20r | Clear Corners w/Blackout | Smoked Frt Markers | Cupra R Lip | 20% Tint
