Results 1 to 18 of 18
    Registered Member Four Rings |Sandman|'s Avatar
    Jan 02 2005
    A6 3.0 TDI QTip
    Lisboa, Portugal
    Correct Tire Pressure for 235/35/R19´s...
    Hey !
    I´m wondering what would be the correct tire pressure for 235/35/R19´s... I´ve read about it and some say 36-38 PSI others say 40-42... what should I do ?? we have L O T S of potholes here in Lisbon and the car WILL have to go over many of them (even though slowly, of course), so, what would be the overall best pressure for the tires ? I drive mostly alone...
    2005 Audi A6 3.0 TDI Quattro | 2002 Supercharged 330ci
    AKA Silveraudi
    Veteran Member Two Rings socaudi's Avatar
    Jul 03 2004
    Socal
    Re: Correct Tire Pressure for 235/35/R19´s...
    I run mine at 40psi. I wouldn't run anything less if you have potholes to deal with.
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    There is no "correct" tire pressure. At a lower pressure of 35 the ride is going to be more smooth and soft. At 40 your going to have better protection for your wheels. So you just have to find a balance of the two that best suites your needs.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    38-41 psi would be fine if you have potholes to deal with. The lower = more comfort but as actlsub9 stated the higher psi will give the wheel more protection.
    Veteran Member Four Rings RAVI's Avatar
    Jan 29 2006
    hella stock parts
    bay area-livermore-ca
    i run 35 and 32 in the back
    '02 Audi A4 1.8BTQM
    Jan 02 2005
    A6 3.0 TDI QTip
    Lisboa, Portugal
    okay, I´m gonna try doing 41 front and 38 rear ? would this be good ? or should I do the same pressure all around ?
    AKA Silveraudi
    Veteran Member Four Rings Doss's Avatar
    Sep 18 2006
    Tools
    Top of the Mountain
    Sandman, I do not recommend 41 psi in your tires unless you are putting in nitrogen.
    There is no correct tire pressure as stated above.
    The most important thing to do is check what the maximum tire pressure is for your particular tire. If you want to put in air, take the max psi rating and back it down by about 6 psi (if you're using air). For nitrogen, you can back it down by about 3-5 psi.
    Tires fail due to under or over inflation (among other reasons). If you set it too high, the ride is going to be stiff and you'll risk blowing out the tires on hard hits. Too low, and the tires will be soft, less responsive, and may overheat.
    Again, tire pressure is dependent on several different factors:
    1. Max psi rating
    2. How stiff or soft you want the ride
    3. Road conditions
    4. Load
    5. Tire wear
    So, I guess the short response would be that 36-38 psi is safe for most tires.
    Doss --------- ESP & SM SCCA racer
    '95 Mustang Cobra hardtop 'vert ---- Modified 6.4 F250 ---- '13 Audi allroad
    Originally posted by remembertofocus
    its just that you seem to constantly come off as an ass... maybe try putting it in your sig
    Me
    "Without failure, there is no progress. " "Taking the first step wrong may be the best thing you ever did."
    Veteran Member Four Rings PS8boost's Avatar
    Feb 26 2005
    05 A4(GONE), 2010 Prius, 2015 A3 8V 1.8
    909 AUDI CLUB IE
    38 all the way around here
    2015 Audi A3 8V 1.8FWD
    USP CLUB MEMBER #29 - GONE
    Supremely practical, yet utterly thrilling to
    Dec 05 2004
    The Sunshine State
    I run 40 all the way around. I think MC Hammered once said, take the max tire pressure I think in my Falkens its like 51 or 50 and subtract 10 psi from there. Butler Tire here in Atlanta recommends 35 for my 19s if you want a more comfortable ride. If you want somewhere in between I say 38, but also depends on how aggressively you drive.
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    38-40.
    Nitrogen is your friend. Get them filled up and you'll be happy.
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Feb 24 2005
    Santa Ana
    I always run 5 psi lower that the max psi figure listed on the tires. Different makers have different max psi's. Examply: Max 45, i run 40 psi. Safest way around.
    Established Member Four Rings A4TL's Avatar
    Nov 06 2006
    335is
    atlanta
    nitrogen? you get that free with air :)
    lol.
    load rating of tires
    weight of car (with junk in it, including bodies)
    do you want it to wear on inside or outside of tires(knowing the front end takes more weight regardless)
    do you want to bend the rims and ride comfortably, or take harsher ride and less chances?
    consensus was something like 32-34 for 16's, 36-37 for 17's, 38-40 for 18's...
    The load rating of the tires compared to the weight of the car and the weight distribution seem to be the magical #'s to figure out.
    A4's are nose heavy so you can easily wear the centers (overinflation) of the rears out while wearing out the outers (underinflation) of the fronts.
    Good advice from da man on this problem: every 5K when you do the oil, have them rotate the tires. it takes like 10 minutes tops to do a simple front to bad (directional tires) your local vag shop might charge you $15 extra.
    Veteran Member Four Rings norcatalyst126's Avatar
    Galt, CA
    I am ashamed to admit that it has been a few months since i have last checked my tire pressure. Actually, I usually have America's Tire Co. check it. Well, I am not trusting them anymore. The fronts were at 25 and the rear at 30. I adjusted them all to 40psi. Took the car for a little drive, and was AMAZED at the difference!!!
    need rotors?...adam's rotors
    Veteran Member Four Rings Toast's Avatar
    Jul 05 2004
    2014 X3.5m
    San Gabriel
    also pressure will increase with heat, if you are too high (>40) psi will most likely increase after drive
    2010 A4 Avant
    Veteran Member Three Rings Carbon's Avatar
    May 24 2005
    2004 E46 M3
    San Diego, CA
    i run 38 psi all around too
    03 A4 - Sold
    Veteran Member Three Rings youngspeed's Avatar
    Jan 14 2005
    RS4 Avant, A4 1.8TQM Avant 05, EVO X 08
    Spot marked X
    35 hot, 38 cold.
    SQ5 B8 white
    REVO STG 1+ SINGLE PULLEY,APR CPS, APR 3.0T CARBON FIBER INTAKE, 034 THROTTLE BODY SILICON HOSE, 034 REAR ARB, 034 TRANSMISSION AND DIFF MOUNTS, KW V3 COILOVERS, AP RACING BBK, LEYO V1 PADDLE SHIFTERS.
    PAST RIDES - RS4 B7 MISANO RED. GIAC TUNED, MILLTEK.y
    2015 SUBARU WRX STI, ECUTEK TUNED.
    EVO X. ECUTEK, HKS EVERYTHING
    GTRS BT A4 1.8T TQM UNITRONIC TUNED
    A6 C5
    INTEGRA GSR
    Nov 06 2006
    335is
    atlanta
    does tire pressure affect road hazard? if the tire is super inflated say to 40psi(cold) would it be more sensitive to crap in the road, say a rock?
    i only rock 40psi because the roads are rough in the city and no wheel is immune to nasty bumps and potholes.
    i am going to go to 5 wheel rotation since i blew out one tire (1K miles) and got a new full size spare (0k miles) every 5K to see if it extends the life.
    but we all know that most high performance summer tires are good for like 20K.
    we all drive hard and adding suspension mods like sway bars (rs4 rear throws alot more stress on the front tires) it must have some synergy with the tire pressure.
    more weight up front, more traction (rs4 rear sway), driving habit, RATING OF TIRE.
    also wouldn't offset and stagger have some effect?
    02 1.8tqs - apr 1+ - SS forge - Hartmann B5 RS4 18" ET35 - Delsa (ebay) spoiler lip - debadged, B7 A4 320mmx30 front brakes - 335i Montego Blue/black; Sport;Prem; iDrive; Step and Heated Seats.
    Jun 21 2005
    Milton, Ontario
    I've got 245/30/20 and I run 38psi all around cold. No problems yet and it's comfy to boot.
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    2014 Dodge Grand Caravan
