Results 1 to 6 of 6
    Registered Member Two Rings VBS4's Avatar
    Feb 05 2006
    Va Beach VA
    Advice on tires to purchase 235/35/19's
    I'm getting some 19X8.5 rims and I could use some advice on tires.
    I'm looking for a decent tire at a decent price, good all around handling characteristics(summer tires) and preferably (not mandatory) a stiffer sidewall to give more protection to the rims.
    Weight is not a huge priority but it does factor in somewhat.
    Here's what I'm looking at so far (all tires 235 35 19's).
    Bridgestone Potenza RE050A PP
    26 lbs $217
    Bridgestone Potenza RE750
    25 lbs $160
    BFG
    28 lbs $189
    Kumho Ecsta SPT
    25 lbs $136
    Yokohama AVS ES 100
    23 lbs $171
    These tires can all be found at
    www.tirerack.com
    I would love to hear first hand experience with the above.
    Opinions/advice welcome
    2005 Silver S4: Sold
    AWE Non-Res Catback: Sale pending
    Tein Super Street Coilovers: Sold
    19" Silver BBS RGR's: For Sale
    10" sub box that hides in trunk cubby: For Sale
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Re: Advice on tires to purchase 235/35/19's
    I've had a chance to drive on all but the RE750's. and can offer the following;
    RE050a PP: about the best tire in wet, fairly quiet, nice responsiveness
    ECSTA SPT: very balanced tire, not as strong as the best, but a great value......
    ES 100: older design and tech, decent traction but a little noisier than most
    KDW2: decent traction wet and dry, even noisier than Yoko
    Depending on your needs, I'd go Kumho (best dry) or Bridgestone (better balance wet and dry).
    We normally do a 245/35R19 for S4 ... but that's at stock ride height.
    Senior Member Two Rings b7cruiser's Avatar
    Jan 16 2007
    B7 2.0T
    So Cal
    Quote Originally Posted by VBS4 View Post
    26 lbs $217
    25 lbs $160
    BFG
    28 lbs $189
    Kumho Ecsta SPT
    25 lbs $136
    Yokohama AVS ES 100
    23 lbs $171
    www.tirerack.com
    RE750s - A little hard but very driveable (compared to BS S03s and Yok AVS). Tires have a rib that will extend past the lip of the rim. If you can deal with it, worth getting for low profile wheels. Gave a little more protection on my RGRs (E39 540 with 19x9 245/35-19 and 19x10 275/30-19) from all the road junk that flies around on the freeway.
    Sep 19 2006
    Northwest USA
    I'm in the same boat, i really like the reviews on the RE050a PP but they say "NA" in all the snow/ice categories. Anyone know how bad they are in these conditions? I'll probably get snow tires but i dont want to be in a bind if it snows unexpectidly.
    Oct 06 2006
    South Bend, IN
    Summer compounds get very skittish below 40 degrees, so we don't ask for winter weather reviews. Rubber will harden up to the point where it feels like you are riding on the bare wheels, and the tire cannot flex or grip the road for any substantial wet traction.
    Feb 05 2006
    Va Beach VA
    Quote Originally Posted by Doc@tirerack View Post
    Just spoke to Doc on the phone. The above was meant for the ECSTA MX not the SPT. He said the SPT gets really good reviews.
