Results 1 to 12 of 12
    Registered Member Four Rings CarterMarkham's Avatar
    Aug 05 2005
    2008 Legacy GT
    Maine
    P0730 - Gear Ratio Monitoring: Incorrect Gear Ratio
    Address 02: Auto Trans
    Part No: 8D0 927 156 DL
    Component: AG5 01V 2.7l5VT USA 1617
    Coding: 00032
    Shop #: WSC 06435
    1 Fault Found:
    17114 - Gear Ratio Monitoring: Incorrect Gear Ratio
    P0730 - 35-00 - -
    What the hell does that mean? I cant find anything on here pertaining to that code.
    2008 Subaru Legacy GT
    http://www.MainelySubarus.com
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    Re: P0730 - Gear Ratio Monitoring: Incorrect Gear Ratio
    Auto or Manual?
    Have you changed the wheels / tires to anything besides the original size? The only time i've heard of this code is when someone has changed their tires and the ecu gets confused...
    (From a Jag Forum)
    "Have you changed the wheels/tyres to any other than original size? The gearbox sends the gearratio to the ems, which calculates it's own from engine speed and vehicle speed. If this is within a certain range, the ems assumes correct gear ratios. By changing the wheel diameter, this error code can flag up.
    Another possibility is torque convertor slip, is the box low on oil?"
    --Adam
    Have questions? E-mail me.
    Sep 14 2006
    14 GLI
    Through searching around google, i've been seeing this code in mercedes in regards to a faulty wiring harness as well, though that may be a mercedes problem.
    This is a pdf of that code from a mercedes "vag" readout. Note the probable reasons for the code.
    http://www.mercedesshop.com/shopforu...2&d=1170130687
    --Adam
    Aug 05 2005
    2008 Legacy GT
    Maine
    I have an auto. Heres what happened. I was moving my car onto the lawn, which is covered in snow so I could vaccum it out. Our lawn is raised up about 3 feet or so from the driveway, I came up at an angle so I wouldnt hit bottom. I got stuck and turned ESP off, proceeded to "floor it" to really get the EDL working and then I noticed that my transmission went into limp mode. the PRND432 was lit up backwards. I shut the car off and turned it back on took it for a ride, and things seemed to be ok.
    I could believe that the wiring is fucked up because my tranny and engine were removed from the car when I had my turbos replaced, 800 miles ago.
    Aug 05 2005
    2008 Legacy GT
    Maine
    Quote Originally Posted by 1997gtx View Post
    Auto or Manual?
    (From a Jag Forum)
    --Adam
    I have 16 inch wheels with tires that should come out to match the same as stock. I got them from Tire Rack which they said were "Audi reccomended".... BUT sometimes when I take off from a start the ESP light will flicker even when I am on dry tar, and definately no wheel slipage.
    Veteran Member Four Rings damnthemansam's Avatar
    Sep 20 2006
    motorcycles, boats, other cars and a longboard
    san jose, ca
    Quote Originally Posted by CarterMarkham View Post
    do 16s even clear our brakes
    Aug 05 2005
    2008 Legacy GT
    Maine
    Quote Originally Posted by damnthemansam View Post
    yes, with 3mm spacers. These are my winter wheels
    Aug 05 2005
    2008 Legacy GT
    Maine
    anyone else have any input?
    Sep 14 2006
    14 GLI
    Nope, just me :) Did you clear the code? And if so, has it come back?
    --Adam
    Aug 05 2005
    2008 Legacy GT
    Maine
    --Adam
    Dealer cleared it. My car was in today for combi valves and a solenoid per their screw up. So I brought up this code. I just suggested it might be due to them taking the tranny out when they did the turbos. They say they didnt find anything and the car runs OK I guess. I still dont think it runs smooth. Somethings not right but what can you do?
    oh well. I was thinking of trading in a year for a LGT. I need something new, AWD with a warranty, and something that wont break the bank.
    Veteran Member Four Rings McKennaS4's Avatar
    Sep 24 2006
    2500 dodge ram diesel
    Boston, MA
    my S came with stock audi wheels off of idk what audi... they are 16's and fit with no spacers on both of my s4's... i was baffled but owell? haha
    01 Casa sedan 6MT, sport, cold
    Veteran Member Three Rings IamEzraM's Avatar
    Jul 21 2005
    2001.5 Audi S4 Santorin
    Bedford/MA
    seriously tho, turning off the ESP and 'flooring it' ? That's probably the worst thing you could've done. EDL can transfer some power, but it's not anything close to true locking 4wd, and it's not there to get your car unstuck
    My car is fast
