Results 1 to 15 of 15
    Jan 20 2007
    Earth
    A6 Alignment Specs
    What are the factory settings?
    Veteran Member Four Rings TheBlueMartin's Avatar
    Jan 06 2005
    2006 A6 3.2, 2009 Q7 4.2 Prestige, 2014 Regal GS M/T
    Ann Arbor, MI
    Re: A6 Alignment Specs
    still need these?? If so, just let me know what engine/susp setup you have.
    "Mastering others is strength, mastering yourself makes you fearless" Lao Tzu
    2006 A6 3.2 Avant- Black.
    2009 Q7 4.2 Prestige - Lava.
    Jan 20 2007
    Earth
    Yes, please.
    2000 A6 Avant Wagon
    2.8L Quattro
    Jan 06 2005
    Ann Arbor, MI
    Quote Originally Posted by mmmjboner View Post
    2000 A6 Avant Wagon
    2.8L Quattro
    Front Camber: -1.3 to -0.4
    Front Caster: no spec range
    Front Toe: 0.08 to 0.25
    Cross Camber: -0.5 to 0.5
    Total Toe: 0.17 to 0.50
    Rear Camber: -1.2 to -0.2
    Rear Toe: 0.05 to 0.22
    Cross Camber -0.5 to 0.5
    Total Toe: 0.10 to 0.43
    Jan 20 2007
    Earth
    Perfect, thanks!
    Jan 06 2005
    Ann Arbor, MI
    Are you having alighnment problems??
    Veteran Member Four Rings Betty Humpter's Avatar
    Oct 04 2006
    1993 Ur S4(cinny),03 A8L,11Yamaha Griz 4x4; 12 Yamaha 450
    Pittsburgh
    Good alignment makes a big difference...
    KURTTRO
    "If speed kills, then do brakes give life?"
    1993 Ur S4 "cinny"
    2003 A8L
    2011 Yamaha Grizzly Special Edition
    2012 Yamaha Grizzly 450
    Jan 20 2007
    Earth
    Quote Originally Posted by TheBlueMartin View Post
    Nope, I just changed my outer tie rod ends and need to get the toe set properly. My buddy is going to do it for me at the local toyota dealership for $25 and I wanted to make sure I had the correct specs.
    Jan 06 2005
    Ann Arbor, MI
    did you coat the threads in anti-seize first?? Its a good idea if you want to have a chance to break them loose in a few years.
    If he's got a Hunter alighnment machine, the specs should be in the PC already. If the camber is too far out in front, you'd better take it to a dealer. The subframe has to be shifted to equal camber, which is a bear to do. There is also vertical toe adjustments that are related to bump steer, which only an Audi dealer will know how to set properly (although they may skip that step unless you ask them to set it).
    Sorry I dont work up there anymore, otherwise id be able to help you out.
    Jan 20 2007
    Earth
    Damn.. yeah I think everything but the toe should be fine. I took the car in for a couple of recalls recently (that's how i found out the 'rod ends were bad) and they quoted me $170 for the alignment, now i know why it's so much.
    Jan 06 2005
    Ann Arbor, MI
    how'd it come out at Toyota?
    Jan 20 2007
    Earth
    Yeah, um, it didn't. One of his co-workers got fired last week for working on someones car for $$. So I guess I'll have to get it done somewhere else now.
    Jan 06 2005
    Ann Arbor, MI
    Yeah, a lot of dealerships are getting very finicky over who works on what. Ive had to deal with a new tech bring in 3 'friends' cars in the past 4 weeks for major work off the clock. He wont be fired as of now, but the managers are re-issuing warnings for everyone about doing side work.
    If you take it to O'Patrick or Gurley Leap, make sure you get a before/after printout, and ask if they do drop-toe adjustment. ;) They'll hate you for asking, but its worth it.
    May 26 2011
    Sćo Sebastićo - SP - Brasil
    allroad 2002 camber/alignment specs
    Hi TheBlueMartin.
    I need the specs of the Audi Allroad quattro 2.7 t 2002. Do you have?
    Are they the same of the mmmjboner“s 2000 A6 Avant Wagon 2.8L Quattro?
    Thanks in advance.
    Sep 20 2021
    Kansas, USA
    Kirst, ....or TheBlueMartin
    this post pretty old, but I'm refurbishing my 2001 Allroad C5 2.7t and wanted to know
    if you ever got the camber and toe specs...
    and 2ndly, did you do this yourself..? did you use the string technique...? and what is
    the issue with sub-frame alignment, and how did you deal with it...
