Results 1 to 13 of 13
    Established Member Two Rings kashutu's Avatar
    Dec 30 2005
    A4 1.8T
    MA
    My car is skipping. Need some help!!!!!!!!
    Hey guys, this started yesterday. I was driving, and I was passing this jerk who wasn't giving way to pass, and I felt the skipping from my engine. I thought it was my imagination, but everytime I shifted down, and try to accelerate, I felt skipping. There is no engine light on, I am not sure what is it?
    If anyone of you know whats going on, I can use some help. Thanks
    Veteran Member Four Rings 1point8teeNW's Avatar
    Nov 11 2006
    North Webster, IN
    Re: My car is skipping. Need some help!!!!!!!!
    coil pack maybe? Mine did that and for the first couple times i didn't have a light. Turns out the pack wasn't COMPLETELY bad....just on it's way out. I replaced it and no trouble since.
    Current - 2004 Pontiac GTO 6M *FOR SALE*
    Looking for - B6/7 S4 TIP or 6M
    Dec 30 2005
    A4 1.8T
    MA
    How much am i looking for coil pack?
    Registered Member Four Rings A4 ABT's Avatar
    Feb 23 2004
    03 A4 1.8T Quattro
    Sunshine state
    Re: Skipping when TURBO kicks in!!!!!!!!!!
    is your car stock??
    '03 A4 1.8t Quattro
    Exterior:USP front w/ Kerscher splitter--ABT sides--Votex rear--S4 trunk spoiler--S4 Door Blades--Euro blindspot mirrors--19" ACE Klassik
    Brakes/Susp.:NS rear swaybar--Audi Sport Suspension--NS brakelines--ECS OEM 3.0L brakes--Hawk pads
    Engine:GIAC K04--Genesis 380cc injectors--Okada CP--AWE Tuning FMIC--APR stealth exhaust--ER Test Pipe--Carbonio V2--Forge Splitter--Forge TIP--NS snub mount--ECS Stage 3 Clutch
    Interior:AWE Tuning Boost Gauge
    Senior Member Three Rings myaudibaby's Avatar
    Aug 04 2004
    FULL! I need a bigger garage!
    valencia, CA
    Quote Originally Posted by kashutu View Post
    Hey guys my car is jerking whenever the turbo kicks in. I don't know whats wrong. It started yesterday. If someone can help me figuring out this problem. Whenever I try to floor it, there is a jerk, and then it runs fine. Anyone had that problem, and what was wrong?
    I appereciate your help. THanks
    change your sparkplugs. can be also a boostleak or a coilpack problem.
    "pinoy@audi" at audiworld
    TRACKS ARE FOR TRAINS! I RUN ON THE STREET!
    MY RIDE
    http://i76.photobucket.com/albums/j1...e/IMG_0899.jpg
    E46 05 M3, jet black on black
    Marin, Ca
    does it have a large loss of power or does it jerk and then its fine?
    Dec 30 2005
    A4 1.8T
    MA
    It is stock. It jerks whenever i try to accelerate fast, and then it is fine afterwards. It doesn't have a large loss of power. Power seems to be fine.
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Someone chipped the car w/o your knowledge?
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Nov 11 2006
    North Webster, IN
    VAG your car for misfire codes. If you don't have a VAG-COM like me...take a trip to Auto Zone or Advance Auto Parts. Of course this will only work if your CEL is on. When i had a coil "on it way" out, but not completely bad, I could clear my code by removing the NEG battery cable and the light wouldn't come back on until a made a run up to the redline. This caused the ignition system to be worked pretty hard and caused the misfire which gave me the code and i was able to have the code pulled by Advance.
    http://www.ecstuning.com/stage/edpd/...ory=Electrical
    Go there.
    You'll want the revision "R" coil packs. They're the latest. They all suck, just the R's suck alil less. As you see the hitachi coil packs are availible and they're being experimented with as you may have read on another thread.
    The ECU Tuning ones are backordered, but you can take that part number to your dealership and they should have them on hand. That'll save you the hassle of them needing to do a VIN search to find the coilpacks. Buy a set of 4, it's usually cheaper.
    Another thing....Copper plugs. They're great, but do go bad quickly. If you have high mileage change to BKR6e's. They're around 2 bucks a plug. That may help your issue as well.
    Notice I didn't tell this guy to SEARCH and leave him out to dry.
    Veteran Member Four Rings A4Shizl's Avatar
    Jun 11 2004
    2003 Audi 1.8T, 2005 Honda
    Inland Empire
    its a coil pack going bad... $40 each..
    Veteran Member Three Rings trautob's Avatar
    Feb 27 2006
    Audi A4 1.8T B6
    Newport Beachhhhh
    1point8teeNW = good samaritan
    If I live in an area where its about 60-70 degrees year round I heard the NGK7REs are the way to go? Is this correct.
    Dec 30 2005
    A4 1.8T
    MA
    Guys thanks a lot for your help......I finally got it fixed.....It was the #3 coil pack. My car is running smmoth now.............
    Veteran Member Three Rings Carbon's Avatar
    May 24 2005
    2004 E46 M3
    San Diego, CA
    get some ngk bkr7e's and you will be just fine
    03 A4 - Sold
