Results 1 to 8 of 8
    Registered Member Three Rings int2str's Avatar
    Jan 16 2007
    2002 Audi A4 3.0 Quattro (M)
    San Diego, CA
    Question A-pillar interior removal with curtain airbags?
    Hi all!
    I'm planning on installing a Bluetooth car kit in my 2002 A4 3.0 Q. It has a big old "airbag" sign on the interior piece that starts out as the A-pillar ans then extends past the drivers side hand-grip almost to the B-pillar.
    I believe there is a DIY here somewhere on how to remove it, but I don't think it was on a B6 with a curtain airbag.
    So my question is:
    Is it safe to remove this piece over the airbag or am I playing with fire here?
    Jan 16 2007
    San Diego, CA
    Re: A-pillar interior removal with curtain airbags?
    Found the DIY again:
    http://audizine.com/forum/showthread.php?t=104972
    Looks like his had an airbag after all. So I assume it's safe?
    Veteran Member Four Rings 3.0L AUDI A4's Avatar
    2004 A4
    Central Jersey
    I dont see a problem with it.. from those pics doesn't look like anything is connected to the pillar... You should be cool!
    Mar 29 2005
    Acura MDX
    New England
    Quote Originally Posted by int2str View Post
    yes, you can remove the A pillar safely.
    the a pillar is secured by the torque screws as posted.
    you'll need to pull the pillar out ie perpendicular to the door frame to pop three metal latches that hold it in...after you pop those, you'll need to pull backwards to remove it (there's a slot at the windsheild where the A pillar piece slides into)
    I've done this install 3 times with an install/deinstall/install.
    '12 Golf .:R /
    Jan 16 2007
    San Diego, CA
    Once you got the A-pillar cover off, is there an easy way to pass a wire down to the fuse box? And how do you get from the fuse box to the glove compartment (or behind it) easily?
    Mar 29 2005
    Acura MDX
    New England
    removing the glove box is easy, just need to make sure you get all the bolts out and it drops right down. feeding a line to the fuse box on the other side of the car just involves snaking it over. Not hard, just make sure you zip tie it down well or they'll rattle. you'll need to pull the radio obviously.
    i didn't remove the fuse box as in the post you linked. i just used fuse taps and spliced the wires onto those. no messing with the actual fuse box.
    good luck
    '12 Golf .:R /
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    haha nice to see my post and pictures get put to use
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    Jan 16 2007
    San Diego, CA
    Yes, great pictures and write-up, thanks!
    How did you get the wire down to the fuse box from the A-pillar?
