Results 1 to 23 of 23
    Veteran Member Three Rings brlukosk's Avatar
    Mar 21 2006
    St.C MN
    Interior exhaust resonance (3k-4k)
    I just recently had a custom magnaflow exhaust installed after i finally pieced one together. Pipe is stock ID 2.25" Mid straight through resonator (cheap ass) and magnaflow rear section polished SS muffler, (2.25 in dual 3 out).
    Overall it sounds good, REALLY deep. I mean, it sounds like I have a couple of 12" subs in the trunk playing a midbass sweep. It is really loud around 3/4k inside the car, however outside it really isnt that bad.
    I was wondering if I should get a better resonator for the mid section from magnaflow, either a magnapack or just a satin straight through.
    OR if I should attempt to add some sound deadening in the trunk to get rid of the big loud sweet spot around 3-4000 RPM's. I would probably get some eDead from elemental designs and do the trunk as well as right above the muffler under the car.
    Anyone have any experience?
    Senior Member Three Rings kjr7888's Avatar
    Nov 23 2006
    NH
    Re: Interior exhaust resonance (3k-4k)
    I have the same problem with the same setup, getting this installed tomorow, ill let you know
    http://vibrantperformance.com/catalo...0c8aa15eb5ed5c
    Senior Member Three Rings wood_e's Avatar
    Dec 07 2006
    Saint Cloud, MN USA
    Try putting in a glasspack. I just installed one today and now my exhaust note is perfect!
    2018 Audi SQ5 Prestige - Daily
    2001 Audi TT Quattro Roadster - Sunny day road tripper
    Mar 21 2006
    St.C MN
    Quote Originally Posted by wood_e View Post
    I did.
    25" Cherry Bomb none the less....
    Vibrant res looks nice, but it has a price tag to go with it.
    Damn car is anoying. exhaust note sounds amazing except for the interior "sonic boom."
    Account Terminated Four Rings
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    its louder inside my car than it is outside and I'm running a 3'' testpipe 2.5'' piping from the turbo back to a magnaflow muffler with no resonators. It sounds great but the drone is ungodly between 3k and 4k but i've become acustomed to it now
    Oct 25 2006
    '98.5 A4 1.8tqm Sport, '01 MDX
    Oxford, CT
    I have quite a drone as well. I have a 2.5" exhaust from the flexpipe back, no resonator, and a Dynomax muffler in the rear. Mine is definitely louder inside than it is outside.
    Mar 21 2006
    St.C MN
    I looked into some sound deadening options.
    I think I am going to try liquid eDead from Elemental Designs.
    You paint it on as a liquid. I think doing the whole trunk floor with a couple of layers should help quite a bit. I think a lot of the resonance comes from the spare tire well.
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    meh, i like the way it sounds.
    its the same pitch as the sax or whatever it is on DMB's Bartender & The Stone.
    Veteran Member Three Rings Naudilos's Avatar
    Mar 16 2007
    01.5 A4 1.8TQ
    Chicago/ Ann Arbor
    I just got a custom 2.5" exhaust with a 2.5" test pipe, vibrant resonator, and a magnaflow muffler. The drone is way to loud, a lot more loud than I thought it would be. Like most guys state above, the resonance around 3-4K rpm is almost unbearable.
    What are a few ideas on how to limit this drone and quite it done a bit???
    1. Put stock res back on?
    2. Put stock cat back on?
    3. ....
    01.5 A4 1.8t Quattro Tip
    - Greddy III Turbo Timer - GIAC-X/Tip Chip - PSI Test Pipe - 2.5" Magnaflow Turbo-Back - S4 Euro bumper - UBERHĂUS RS4 grill - M3 Lip Spoiler - ProSport boost guage - Euro trunk lid - H&R Race Springs/Bilstein Shocks - S4 Side Skirts-
    18" RS4 DTM - 710n - 20% tint windows/tails/side markers - 6000K HID's -
    Jan 17 2007
    2001 A4 1.8TQM, 2009 GSX-R 1000, 1995 Dodge Dakota Sport, 2015 FFR 818
    I've got a 3 inch HFC and 3 inch piping, resonator, and dual 2 1/2 out muffler and the noise is resonating really bad inside the car between 2500 - 3000 rpm.
    I really can't go back to stock... so I'm told a bigger resonator is my only option.
    Veteran Member Four Rings gotaudi's Avatar
    Jan 26 2006
    2001 A4 1.8T
    Socal
    just turn up the radio that is what i do.
    BetaAlphaTau Member#22
    Mods:
    GTRS Elim+Unitronics+ATP high flow mani+Neuspeed TIP+Custom intake+Labree HFC+Apexi AVC-R+APR Exhaust+Precision FMIC+SB OFE Stage 4+034 street density motor mounts+Purems snub+S4 Front bumper+18" BBS RC rims+Neuspeed race springs+Bilstein shocks+Nuespeed sways=
    73 74 69 6c 6c 20 73 6c 6f 77 <--- Look it up
    Jan 17 2007
    The radio won't help prevent the vibration from causing headaches.
    Registered Member Two Rings
    Nov 17 2007
    seattle, wa
    I have a custom cat-back 2.5" with Magnaflow 14815 tips, resonated, and the drone between starts at 2.1K and ends around 3k. It doesn't drone that much on the freeway; it's manageable, but I can see how other people might get irritated because of it.
    2000 A4 1.8TQ Tip
    Oct 30 2006
    B8 A4 Avant 6spd
    My rear speaker brackets rattle at idle, its soo annoying. I'm 3" turbo back into 3" inlet S4 gutted muffler, funnily enough theres no drone.
    -18 718 GTS
    Established Member Two Rings ceas's Avatar
    Jun 12 2005
    Allentown, PA
    the worst droning I've had with my custom magnaflow (no resonator).. was when I was on the highway going uphill in 5th with concrete sound barriers on the sides.. the drone was so bad I felt like my ears were going to explode.
    Pearl White 1998.5 Audi A4 1.8tQM
    Koni | Dahlback | Eibach | PolkAudio | Forge | MTX | Profile | Alpine | ECS Tuning
    Veteran Member Four Rings dualaudi's Avatar
    Dec 13 2004
    allroad 2.7t
    san diego
    anyone think its the custom set up is vibriting on the bottom of the car? My custom setup was great till the stock gutted cat broke at the flange. After we welded it up the drone became super loud.
    I think when we welded it back up it got cocked a bit and is now touching more of the body causing the loud hum.
    (sold) 1999.5tqm :: gtrs, atp 3"TP, tweaked mika t3/t4 8k, adj. fpr, forge 004, MBC, neuspeed: catback exhaust, E-bay special FMIC! 9"x28"x2.75" - SOLD
    https://www.instagram.com/dualaudi/
    Jan 17 2007
    Quote Originally Posted by Militant-Grunt View Post
    You're kidding me? None at all? I'm 3" turbo back all the way too and it's horrible between 2500 and 3000. Nothing rattles normally although there is plenty of rumble...
    Do you find it loud but just no bad resonance or is it actually not even loud?
    Quote Originally Posted by ceas View Post
    I get interesting acoustics beside concrete barriers or inside parking garages but the headache inducing drone is actually when out in the open at WOT after 2500 RPM.
    Veteran Member Four Rings Calabria's Avatar
    Dec 10 2006
    '00 1.8TQM
    LA
    Usually the resonator will keep the drone to nothing, maybe a little. Its also about placement of the resonator that helps drone.
    (Ka-La-Bre-Ah)
    Mar 16 2007
    01.5 A4 1.8TQ
    Chicago/ Ann Arbor
    Quote Originally Posted by DND View Post
    It sure won't!
    So I see a lot of other guys with custom exhaust's are having the same problem, with noise inside the car.
    Is a bigger resonator or using the oem resonator the only solution to this??
    Senior Member One Ring
    Sep 10 2007
    radford, va
    I to am having this problem. First i installed a custom 2.5" catback with magnaflow muffler and the drone was horrible, so i added a dynomax resonator. That fixed it for about a day til the resonator burned in, and then it was just as bad, has anyone had any luck running two mufflers?
    Mar 16 2007
    01.5 A4 1.8TQ
    Chicago/ Ann Arbor
    Quote Originally Posted by Calabria View Post
    So what's the best location for the resonator to help reduce drone?
    Senior Member Two Rings fenderstrat1184's Avatar
    Oct 17 2006
    '00 1.8tqm, '90 jeep cherokee
    northeast
    i had the same exact problem 2.5 piping magnaflow muffler... added a glasspack.. really didnt help, i finally lost patience and just gutted everything and got a borla... couldnt be happier
    but if you really want things to be quiet go with an apr or milltek if you have the $
    What's AOA? If Audiworld is the 1960's, AOA is 'the man.' Don't try to fight the man, because, just like the hippies, you'll lose.
    Dec 10 2006
    '00 1.8TQM
    LA
    Quote Originally Posted by Naudilos View Post
    That i do not know... but Magnaflow mufflers also create a lot of unwanted turbulence through their mufflers...
    Magnaflows B5/6 exhausts are 2.5in to resonator, the, to 2.25in from axle back into a muffler and it supposedly doesnt have any drown. Maybe the pipe break down from 2.5in into 2.25in helps., this also creates more back pressure and less of a bottom end loss aswell.
    (Ka-La-Bre-Ah)
