I would look at Milltek exhausts as well. They do a complete system, or just the car back. You can go with resonated or non resonated, personally the resonated sounds better, with this it sounds like a nice V8 rumble, with teh non resonated it sounds like an after market exhaust if that makes sense.
Expect about 15bhp gains from the cat back system (approx. €1000) and another 15bhp from the free flow downpipes (approx. €1800).
If you remap as well you can expect 12bhp on its own or 20bhp if done with the exhaust, full system or cat backs.
Regarding the 40/60 split, I don't think there is a 40/60 split with any car other than the RS4, I was talking to Audi at Geneva about this and they were adamant that only the RS4 had the rear bias, all A4's and S4's were still 50:50.
I asked again at my dealer when I started looking for an S4 a few weeks ago as I have also come from BMW, 535d sport touring and M3 CSL, and would prefer a rear bias, but again they said that only the RS4 has 60% going to the rear.
The gearing is different on the tip, but to be honest it is for the better, crusing at 100mph in the manual sees the rpm at 4000 and the car using 14L/km, in the tip is is only using 10L/km, big difference.
I have a manual and this is the only thing I don't like about it, the fact 6th gear is so short, if they had made it longer the car would be far better.
The other niggles?
Accelerator pedal is too high, so you have your foot in a position where you get cramp, the A3 has a much better pedal that sits lower and is pivoted from the floor, coming from a BMW you will notice this.
Clutch, too jerky and the pedal is again too high, but not a problem with a tip.
Wallows too much at on cornering and fasr too soft, RS4 anti roll bar helps alot, and better suspension sorts it out a treat.
Far too quiet, doesn't have any bite to it at all, even with the window down you can't hear it, but again if you add an exhaust that sorts that one out.
