Results 1 to 25 of 25
    Active Member Two Rings Talonz's Avatar
    Jan 21 2007
    Northwest
    19 inch or 18 inch wheels
    Hello everyone NOOB posting , own a A4 Avant 04 3.0 lit, currantly running the stock 17 inch wheels, but would like upgrade to bigger wheels, and drop my ride with some stastis street coilovers. Is it true that if I would install 19 inch wheels that my gas milege would drop. Has anyone out there ever came up with that problem??? Or should I just stick with 18 inch wheels and won't have any worries??
    Veteran Member Three Rings Gondi Stylez's Avatar
    Oct 22 2006
    B6 3.0 Q
    Calgary, Canada
    Re: 19 inch or 18 inch wheels
    go for the 19s man! look so much better than the 18s! and from what ive read i dont think the gas milage is of any importance
    '02 DG A4 3.0Q 6MT | Member of Club 3.0
    .:. OEM+ : Custom I.C.E : Vogtland GT : Hartmann : SPP : Hawk : Goodridge : JHM : Apikol : 034 .:.
    Jan 23 2006
    Black 2004 Audi A4 3.0 Quattro 6spd
    Jacksonville, Arkansas
    I ran 19's for a few months before this winter and didn't see any significant difference in gas mileage. 19's fill the wheel well in perfectly and look great with a drop.
    Member of the original 3.0 Club
    Oct 22 2005
    Reppin the Mitten.
    really depends on the road conditions of where you live. Reason i got 18's was because I don't want a bent wheel every other week, and the looks are acceptable. 19's look darn good, but the downside is a heavier wheel, and you can bend them easier. And yes bigger wheels do mean worst gas mileage because of more rotational mass. It may not be that significant, but there is a difference.
    Jan 21 2007
    Northwest
    Quote Originally Posted by vinny.dtw View Post
    Thanks for the reality check, but then again 19's look so sick, but a bent 19 rim, would hurt. So as for the weight would forged wheels be a lighter choice to keep the milege same??
    Registered Member Two Rings 80020vr6's Avatar
    Dec 19 2006
    2007 A4 2.0TQM (Ibis)
    Colorado
    I'm in the same dilema. I think that 18's would look just as good as 19's, with the proper drop.
    Veteran Member Four Rings Howard Hughes's Avatar
    Feb 17 2004
    1.8T Revo3 Q-Tip
    Chicago Illinois
    I used to think that^.... until I saw a car with 18's sitting next to a car with 19's....
    789whp
    Registered Member Three Rings xbatmit3x's Avatar
    Dec 08 2006
    Vancouver
    Quote Originally Posted by Howard Hughes View Post
    i had my friends USP with the stock b5 rs4 (18s) next to mine with my b7 rs4 in 19s and the difference is pretty big... the 18s end up looking like 17s...
    i also made my decision to get 19s based on road conditions... i thought it was safe enough to drive in my area with 19s... gotto be careful tho!
    as for gas mileage there is a slight difference that u will see going from 17s to 19s as i did.. . but with the look of ur car after putting on 19s u will think its well worth it
    -James
    2003 Audi A4 CVT TIP
    / USP Front w. CF splitter / S4 Bixenon Ecodes w. DRL/ Hagus Matte Mirror Housings / 50% Formula One Tint All-around/ Bilstien H&R Supension/ VM V708 19' Gunmetal Rims w/ FK452/ Vibrant 1304 Exhaust Tips/ RNS-E Navigation/ Podi w. VEI
    Veteran Member Four Rings norcatalyst126's Avatar
    Galt, CA
    19's...went through the same decision a few months ago....i bought 19's a few months back, they have a lip so sometimes they almost look like 18's....so, if you got 18's with a lip they'd look like, well, what you already have...IMO
    need rotors?...adam's rotors
    Deactivated Two Rings
    Dec 23 2005
    Las Vegas
    18's with no lip if you want them to look as large as possible, and if you go with an all black wheel it will give the illusion of being larger
    Established Member Two Rings billyboy's Avatar
    Mar 04 2006
    Wilmington, DE
    19's. but spend the extra $1000 or so on good wheels so the probability of them bending is alot less.
    Veteran Member Three Rings trautob's Avatar
    Feb 27 2006
    Audi A4 1.8T B6
    Newport Beachhhhh
    the rs4 reps are insanely strong, i went over a 1 foot curb at 30 mph no bending.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by 80020vr6 View Post
    I wish! My fliks look alrite but Ive been searching for some good 19s forever
    - Clint
    Mar 04 2006
    Wilmington, DE
    Quote Originally Posted by trautob View Post
    well i hit a nasty bump on I95 and now i have a vibration. but im road force balancing the tonight. so we will see how it works out.
    Veteran Member Four Rings Doss's Avatar
    Sep 18 2006
    Tools
    Top of the Mountain
    The difference in MPG is mainly going to be attributed to the weight of the wheel. If you can find some lightweight 19s, you'll remain in the same ballpark as stock.
    I went from 30-32.4 MPG (1.8t quattro manual) to 27-29.5 when I switched. This could also be due to the weather changing too. But, needless to say, more rotating mass will equal a lower fuel efficiency rating.
    Oh, 19s do look better IMO.
    Doss --------- ESP & SM SCCA racer
    '95 Mustang Cobra hardtop 'vert ---- Modified 6.4 F250 ---- '13 Audi allroad
    Originally posted by remembertofocus
    its just that you seem to constantly come off as an ass... maybe try putting it in your sig
    Me
    "Without failure, there is no progress. " "Taking the first step wrong may be the best thing you ever did."
    Veteran Member Four Rings AudiA4Style's Avatar
    Feb 24 2004
    B8.5 S4 l 75 CB550 Cafe Racer
    Go 19's. You won't regret it.
    2013 S4 l Prestige l Moonson Gray l S-Tronic l Sports Diff l Fine Nappa l Carbon Atlas
    2006 S4 l Avant l Premium l Dolphin Gray l MT6 l Bose l Silk Nappa Leather l Gray Birch
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Go with 19's and if for some reason you don't like the ride you can always sell them for a small loss and buy 18's with the remaining money.
    Can't do that if you buy 18's first.
    Senior Member Two Rings Matav23's Avatar
    May 04 2005
    02' A4 1.8tmq, 07' A4 Avant Sline Ti 2.0tqm
    Denver, CO.
    I too was one of the guys who thought 18"s would be a better idea living here in Colorado so I got some. I kept them for less then a year before I got 19"s. I think they look much better and I haven't had any problems with the roads. And no im not running them now, I put my 17"s on for the winter.
    Veteran Member Four Rings ArcticBoost's Avatar
    Jun 19 2005
    2005 Arctic A4
    L.I, New York/CT
    blah blah blah 18's are NOT too small with the drop as many people have said. I was in the same boat and living in new york, I could not afford to take the 19" route just in case. Go 18...they are cheaper and will hold up much better. (make sure the car is lowered though).
    Greg
    2005 A4 1.8TQ 6-Speed
    35% Llmuar Tint || 4300K Xenons || Hyper White Fogs || S4 Upper/Lower Grills || Spoiler Depot Lip
    APR Stage 1 v.2 || STaSIS Streetsport Coilovers || Hyperboost Diverter || EVOMS Intake || Strat SSK || Milltek Fullback || APR Snub
    AWE Tuning Pedals || Apline Type-R 12" Subwoofer || Alpine V-Power Amp || Hardwired Passport 8500 x50
    Jan 21 2007
    Northwest
    All right everyone. I'am convinced that 19's are the way to go and that yurp mass and weight does make a differance as for gas mph. 18 s are also nice and will probably save me some gas, and money but knowing me , satisfying my taste is what its all about . So I just purchused a set of Hartmann Silver RS6-172, 19s X 8.0 with Falken 235-35-19 tires and will be here tommorrow . Then the ride will be dropped with Statis StreetSport coilovers. Thanks everyone for the input.
    TaLONZ
    Veteran Member Four Rings LAZY TURBO's Avatar
    Jun 01 2005
    La Crescenta, CA
    19's!!
    ~Sevan
    USP CLUB MEMBER #1 <~CLICK IT
    Rest in Peace Four Rings adam's rotors's Avatar
    B9SQ5 | B9S4 | HD FXLRST
    i found this out the hard way...
    i used to have 18" RS6's and had them maybe 4 months before i stepped it up to lipped 19's...now im playing around with what 19" i like...
    if u want to max out the look, go with the 19" b6 rs4/usp reps, not the b7's...
    those look like fucking 20s...a lip shrinks them, but then you dont get the dish look...
    19s tho hands down...
    adam | adam's rotors inc. | [email protected] | est. 2006
    customizable factory-fit brake rotors, made-to-order | adamsrotors.com
    follow/like/@/tag @adamsrotors on twitter, instagram, & facebook | #adamsrotors
    Veteran Member Four Rings sliverwagon's Avatar
    Feb 06 2005
    EAI Bareknuckle
    Shawnee on Delaware
    get the 19s you will probably regret not getting them if you get 18s I bought 18s twice but the second set of 18s was such a good price I couldnt pass it up
    Veteran Member Three Rings ewytt's Avatar
    Sep 19 2006
    2016 SQ5, 2012 Turbo Beetle
    i like 18's that have a "extending spoke" design. (like RS4's, DTM's, maybe RS4) the "extended spoke" design brings the design all the way to the tire which gives the illustion that the wheel is still extending which makes them look big. I think my stock sport 17's look like 18's somedays and when i see USP's with the 18" RS4's the look like 19's!
    I want to split the difference and get 18" Hartman DTM's with my 02 sport suspension. I think it will look fine. (just like how stock USP look, almost perfect)
    2016 SQ5 || 2002 Turbo Beetle
    Active Member Three Rings PROXUS's Avatar
    Jul 19 2005
    Chicago
    19"s all the way
    don't buy the stories about gas milege.
