Results 1 to 8 of 8
    Veteran Member Four Rings audimeister's Avatar
    Jan 05 2006
    '07 A4 Avant S line Ti 6MT Quattro
    Oakland, CA
    Thumbs up Tein S Tech Springs review
    As some of you know, I have been transitioning from my B6 to a new B7, and The deal I negotiated with my buddy for my old B6 didn't include the PSS9 coilovers (or RS4 rear sway bar) I was running. So, I've had the car for a week or two fixing up a few things for its new owner, and I ordered a set of Tein S Tech springs so that the car could keep the lowered look, and I could keep the expensive coilovers.
    I installed them a week ago with the original sport suspension (red) shocks that came on the car and an S4 rear sway bar I had laying around. I really wasn't expecting much from them, having done cheap "spring only" upgrades in the past on other cars. What you usually end up with in that situation is an oversprung, underdamped mess of a suspension that is bouncy and harsh at the same time.
    But, I've been driving the car for a week like this and I have to say Tein really nailed this spring upgrade. It works almost exactly like the stock sport suspension, but nicely lowered. The only hint that something isn't stock is after larger bumps at higher speeds, you can feel the front of the car lowering itself back down after extension. It's very subtle, and most probably wouldn't notice it.
    One other concern that some have with spring only upgrades is that the stronger spring overworks the stock shock, wearing it out prematurely. I'd be willing to wager that these springs are so close to stock rates that the stock shocks should last forever. I was also concerned that a lowered spring with a near stock rate would have the suspension bouncing off the bumpstops all the time. Not so, unless you're really abusive and doing something with the car you shouldn't be doing anyway.
    I just wanted to pass the info along. If you want to lower the car and keep the stock ride (and a pile of cash), the Tein S Tech spring set is the way to go.
    "Obsessed" is a word that the lazy use to describe the committed.
    Established Member Two Rings Rulez's Avatar
    Nov 02 2006
    2011 Audi S4
    Orlando, FL
    Re: Tein S Tech Springs review
    Good info man :)
    Mike Rule
    2011 Audi S4
    Established Member Two Rings BLACK JEFF's Avatar
    Sep 14 2006
    VA
    any pics of the stance with the tein S Techs?
    Jan 05 2006
    Oakland, CA
    Quote Originally Posted by BLACK JEFF View Post
    No, I need to take some. The car looks like it has '02 sport springs- slightly lower than the original sports that came on it, but not slammed.
    In Limbo Four Rings Sydeshow MO's Avatar
    Sep 14 2006
    B6 Avant-Xterra-FORD p/u
    NOR*CAL, Vallejo
    Good info mango! My 02' sport is freaking bouncy as hell. I wonder if I need new shocks and struts???
    Im gonna get some springs and will probbly go the Tein route. If I find out the shocks and struts need a R&R then im going Stasis coil over.
    My new shoes will look sooo dicked on sport susp. w/ that huge gap in the front.
    Jan 05 2006
    Oakland, CA
    http://www.tein.com/ti/g70.html
    Pics and specs. The car in the photo is a little lower in front than mine, but not much. The Rieger kit makes it look lower, too.
    Senior Member Two Rings AudiiB6's Avatar
    Nov 29 2009
    any pictures of the car with the tein s tech on ??
    Veteran Member Three Rings Scrwedtxboy31's Avatar
    Oct 19 2008
    2004 A4 1.8TQM (6sp)
    VA
    Quote Originally Posted by AudiiB6 View Post
    Yea link didnt work but I would really like to see your car specifically on the reds.. I've been contemplating this for a while as I have the s techs laying around and jsut got stock sports put on... im a little too high for my taste.
    -Eric
    R 1 3 5
    2 4 6
