Page 1 of 4 123 ... LastLast
Results 1 to 40 of 145
    GTA, Canada
    Post B5 A4 Easter Eggs! Features not found in the owner's manual.
    Lets get this going again. There are lots of features that are hidden from us, lets expose them all for the B5!
    RippleChip (Ryan) - Moderator
    Audizine
    01.5 eh4 1.8T || 12 eh5 2.0T
    Veteran Member Four Rings Mattgfx's Avatar
    Sep 27 2006
    Re: Easter Eggs...Features Not In The Manual
    sun visor in the middle, next to the lights and sunroof controls :)
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW 328i xdrive
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Veteran Member Four Rings a4cefed's Avatar
    Mar 15 2005
    06 GTI / 02 325ci
    chicago
    ^ also used to block the red from appearing in the rear view when fliped to dim
    06 Reflex Silver GTI Package 2 DSG
    [ Vogtland Race Springs/A8 wheels/Eisenmann Exhaust/Eurosprot Intake]
    For weekly Chicago meets/ GTGs check out :
    Illinoiseuro.com
    Established Member Two Rings tombomb84's Avatar
    Sep 14 2006
    99.5 A4 1.8T
    mi
    Also if you put your key in the door and turn it your windows will roll down, as well as roll up when turned the other way.
    Registered Member Two Rings
    Jan 03 2007
    R32
    Plymouth
    If I remember correctly if you hold 2 buttons on the heater controls you can view a ton of different engine diagnostics etc...
    Veteran Member Four Rings jbrentd's Avatar
    Oct 31 2005
    '13 allroad, '91 Coupe Quattro, '64 Corvette, '93 Corvette, '21 Bronco
    Tulsa, OK
    Quote Originally Posted by Audilover08 View Post
    It's mostly climate control diagnostics, but there is some engine data there. Here's an AW tech article.
    http://www.audiworld.com/tech/int6.shtml
    1991 Coupe Quattro - Project Car
    2013 allroad - My DD
    2011 A3 S-Line - Son's DD
    SOLD - 2007 A6 4.2L // 2001 Pelican A4 Avant // 1996 A4
    Veteran Member Four Rings Starting's Avatar
    Feb 13 2004
    98 A4 1.8t
    Central, NJ
    You can reprogram the windows with a vag so they roll up and down with just the remote and you don't need to put the key in the door.
    Veteran Member Four Rings fred2ka4's Avatar
    Nov 26 2005
    Audi A4, Honda Pilot
    NM
    Quote Originally Posted by Starting View Post
    Yeah, when I arm my alarm and push and hold the button the second time it will close my windows and my sunroof, but I don't know if the opposite is true.
    But I thought that was normal.
    BetaAlphaTau member #18
    2000 Audi A4 w/ APR stage III & ...
    APR // GReddy // RACETEC // Bilstein // IForged // ECS Tuning // STaSIS // Neuspeed // H&R //
    And a whole bunch of other stuff ...
    http://i78.photobucket.com/albums/j9...4/fredscar.jpg
    Senior Member Two Rings deux321's Avatar
    Oct 21 2004
    2001 a4 1.8tqms
    central cali
    the opposite IS true. just hold the unarm button down that one should open your windows.
    Nov 26 2005
    NM
    Quote Originally Posted by deux321 View Post
    So will it open the windows to where they were previously, or all the way?
    I guess I should try since I never have ........
    Oct 21 2004
    2001 a4 1.8tqms
    central cali
    all the way or where ever you want it to stop.
    it does not have like a preset memory or anything.
    if you want it half way just let go of the button..
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    here is the trick to unlocking the "secret EQ"
    To access the EQ all you have to do is turn off your car and remove the key. Then hold down the number '5' on your CD changer/Radio preset control and power on the head unit.
    You will see '55555555' if your radio is in stock form. These numbers represent 4 EQ settings each for front and back. They are, in order from left to right (courtesy of LCP on the AudiWorld forums):
    1. Front low bass
    2. Front mid bass
    3. Front midrange
    4. Front treble
    5. Rear low bass
    6. Rear mid bass
    7. Rear midrange
    8. Rear treble
    To adjust the settings, use your volume knob to change the flashing digit to a value from 1 to 9 (1 being the lowest level, 9 being the highest) and press P.SCAN to go to the next digit. When you get to the end it will wrap back to the first digit.
    The most popular settings for bose seem to be 88698869, however after a bit of testing with my favorite music, I found that to sound boomy and hollow and have since gone with 76567656. My next task will be to increase the directional (midrange and treble) sound on the front speakers only to bring the Bose sound stage back towards the front without sacrificing bass out of my rear speakers.
    The best setting that I have heard for the non-bose system is 38679657. It still doesn't sound like bose, and certainly not like a good after-market setup, but it's a major improvement for those that wish a simple change to improve their overall sound and reduce distortion.
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Sep 17 2006
    SLC, UT
    VAG-COM tricks to make your windows roll up with the key fob, One touch unlock of all 4 doors and trunk, Auto lock/unlock of doors, and other things
    Recode locking options
    [Select]
    [35 - Cent. Locks]
    [Recode - 07]
    Enter the coding below
    [Do It!]
    Write down the existing coding for future reference.
    A4 pre-1998 with Delta radio and anti-theft system
    Standard Coding: 03468
    A4 pre-1998 with Delta radio, anti-theft system and keyless entry
    Standard Coding: 12172
    A4 1998+ with Concert/Symphony radio and anti-theft system
    Standard Coding: 03340
    S4, A4 1998+ with Concert/Symphony radio, anti-theft system and keyless entry
    Standard Coding: 16140
    Add the following options to your coding number:
    +64 Windows up, sunroof close, and windows down with remote.
    -04 One touch unlock of all 4 doors and trunk
    -1024 Remove horn honk when arming
    +32 Auto lock/unlock of doors (Doors lock at 10 mph and unlock when key is removed)
    So, if you want to have a 1999 A4 with Concert radio and anti-theft system and keyless entry, and you want to add window control with the remote along with auto-lock, then:
    add 03340+64+32= 03436
    Current:
    Previous:
    Sep 17 2006
    SLC, UT
    Alarm Sensitivity Adjustment with VAG-COM
    [Select]
    [45 - Int. Monitor]
    [Adaptation - 10]
    Enter channel 01
    Enter a value between 50-100 (it should be 100 by default) for the sensitivity of the ultra-sound sensors
    [Save]
    Current:
    Previous:
    Sep 17 2006
    SLC, UT
    well this is mostly a DIY'er but it's not in the manual so ill put it up here so we can build this thing
    Increasing the Remote Unlocking Range
    Relocate the antenna that comes out of the box under the rear seat, and thread it up the back of the rear fold down seat. Between the carpeted backing and the seat cushion material. Then across the top a tiny bit so it forms an inverted L shape. The antenna is BLACK and is only attached on one end to the remote locking module.
    What does this do.... Gives a HUGE range on what was previously believed to be a shitty remote. Its not the parts.... its the poor installation of them. That antenna is used for Frequency Modulation reception, FM is line of site, Line of site doesn't mean Superman's X-ray vision, RF signals don't travel through sheet metal too well. So the antenna being under the rear seat, and atop the gas tank and behind the trunk lid and doors, DOESN'T HELP.
    Current:
    Previous:
    Veteran Member Four Rings bellofello's Avatar
    Sep 19 2006
    1992 Chev K1500 reg cab short box/with 3500 diesel drivetrain. 1992 Cadillac 60 Special "pimp juice"
    Ontario, Canada
    torx bolt? where lol it just came off without removing a bolt? Sorry, never really worked on the interior of a car before I've always hovered around body and drivetrain.
    Having trouble finding the antenna could someone circle where it is and repost the image? Or hell just describe where.
    I feel like such a n00b right now lol
    -1999 A4 2.8 quattro
    neuspeed race springs/bilstein shocks
    custom exhaust/intake
    jhm shifter trio/bunch of 034 mounts
    www.gbaycars.com
    Sep 17 2006
    SLC, UT
    sorry, nevermind about the torx bolt.. but im lost in your picture too.. mine has a black box underneath the seat(passenger sidish). i don't know where yours is. it might be different since our cars are different. idk
    Current:
    Previous:
    Veteran Member Four Rings Rosati's Avatar
    Nov 17 2004
    B5 Brilliant Black A4 1.8TQM
    Northern New Jersey
    there's like a million things.
    1. program windows to open with just the remote.
    2. climatronic can display up to 65 features. some are RPM's, KM, oil temp, etc. You can even check engine codes
    3. You can add more bass to your bose system by holding down 5 and the power button, then changing the setting to 88698869.
    4. The interior lights turn on like in an airplane. First the guages, then the radio, then the other lights.
    5. Press the RDS button and it displays the names of songs from the radio.
    There's so much more to list. Just search and a few will come up. Also, check AW.
    more bass? okay so i hold down 5 and the power button. on my stereo the power button is the volume knob right in the middle. i'm assuming that's what your talking about. but what setting do you change? will it be so much bass that my interior speakers will blow?
    i thought you held scan, or RDS AND 5 and turned the power on? i used the hidden EQ on my car and thast what i did.
    if you leave your windows open and get out of the car put your key in the car door turn and hold and your windows come up and your alarm sets.......
    1. To adjust the bose, it's didfferent depending on the model A4 you have. I have a 2000 and it's 5 and the power button, holding 5 first. For previous models, I believe it's the P.SCAN button. Holding down P. SCAN and a number. Some of these features are in your owners manual. We have speed seensitive voulme control with out
    2. You will not need a control module to program the keyless windows. You need the right code and a VAG.
    3. If you have the premuim package in your A4 and you have auto mirror dimming. Your rear and side view mirrors turn green at night if there is a bright beam.
    4. We have speed sensitive voulme control with our cars.
    Just go to AW's tech section, there's tons of stuff in there
    One touch up and down? If so, someone already did the 'mod'. It's a very easy thing to do. Just take off the rear door panels and put a jumper (a figure 8 strand of wire worked for me) between two posts. I know the tech article is on AW. Someone should do a write up and let Anth post it here.
    Later,
    Mike
    Changing Degree Temperature Display
    Press and hold the recirculation button. Then press the temperature up ("+") button to switch between degrees Celsius & Fahrenheit on the Climate Control Temperature and Instrument Panel Outside Temperature displays.
    Code Displayed Value
    2 Digital value of Interior Temperature Sensor, in Headliner (G 86)
    3 Digital value of Interior Temperature Sensor, in Instrument Panel (G 56)
    4 Digital value of Fresh Air Intake Duct Temperature Sensor (G 89)
    5 Digital value of Outside Air (Ambient) Temperature Sensor (G 17), front
    6 Digital value of Outside Air (Ambient) Temperature Sensor
    7 Digital value of Ambient Temperature Sensor At Fresh Air Blower (G 109)
    8 Digital value of Temperature Regulator Flap Motor Potentiometer (G 92)
    9 Delta value of Temperature Regulator Flap
    10 Non-corrected specified value of Temperature Regulator Flap
    11 Digital value of Central Flap Motor Potentiometer (G 112)
    12 Specified value of Central Flap
    13 Digital value of Footwell/Defroster Flap Motor Potentiometer (G 114)
    14 Specified value of Footwell/Defroster Flap
    15 Digital value of Air Flow Flap Motor Potentiometer (G 113)
    16 Specified value of Air Flow Flap
    17 Vehicle Speed (km/h)
    18 Actual Air Blower voltage (Volts)
    19 Specified Fresh Air Blower voltage (Volts)
    20 A/C Compressor (A/C Clutch) voltage (Volts)
    21 Number of low voltage occurrences, non-transient
    22 Cycle condition of A/C Refrigerant High Pressure Switch (F 118)
    23 Cyclings of the A/C Refrigerant High Pressure Switch (F 118)
    24 Cyclings of the switches, absolute non-fluctuating
    25 Analog/Digital value, Kick-Down Switch
    26 Analog/Digital value, Engine Coolant Temperature (ECT) Warning Light
    27 Coding value
    28 Engine Speed (RPM)
    http://www.audizine.com/forum/showth...+touch+up+rear
    press an hold recirc. at the same time press manual flow up button let go of the buttons you should see a 1c where the numbers were press temp up or down and change it the the code number you want (28 but mine was 27) then press recirc button again and it will say your RPM just add a zero to that number my idle said big 7 little 6 so 760rpm
    1. Some cars have gas caps that are not connected to the body, the caps have a notch cut in them that allows you to hook the cap onto the gas door while fueling.
    2. Once the ambient air temp drops below 41F, a snowflake displays next to the outside air temp to warn you of road icing temps. (This is more of a suprise for the warm climate people)
    3. The A/C system will automatically shut down the A/C compressor once the outside air temp drops below 35F. This sucks if you're driving in above freezing temps and it raining.
    4. In the trunk, beside the spare tire well is a tag that lists every option and feature on your car.
    5. The Concert radio only powers the front speakers. The rear speakers have an amplifier that is bolted to the driver's rear speaker.
    6. Activating the rear fog light automatically enables the front fog lights.
    7. The dual rear fog mod makes your car look like the brake lamps in your tail lights are always on. Very confusing for people following you.
    8. The audi dealership usually charges $40 to cut a switchblade key blank. The VW dealerships usually charge $10 for the same thing. (More of a secret for all Audis)
    9. If you open only your sunroof all the way open it may cause a fluttering sound from the air pressure in the car. Turn the knob back one click and it will go away.
    10. Every piece of moving glass in your car has pinch protection, even the sunroof. (I tried it)
    noticed this last night...
    At night, when your lights are on and windows are down, if the driver pulls up any window other than his...the illumination light on the window switch for that door will turn off....
    Nevermind, I tryed the A/C windshield demister thing this morning at about 29 degrees, and the A/C does NOT come on when I press the windshield demister button. I stand corrected...by my self.
    * Gone but not forgotten - BTA4 GT28RS w/ all mods 400chp
    https://www.facebook.com/media/set/?...1463643&type=3
    Current: 1994 Mazda RX7 Chaste White
    DIY B5 Head Replacement Guide: http://www.audizine.com/forum/showth...al-and-Install
    Nov 17 2004
    Northern New Jersey
    To get more range on your remote, open up your key, put it to your neck, yes, your ncek, and then press lock or unlock , using yourself as an antenna
    Oct 31 2005
    Tulsa, OK
    I can't get my VAG-COM to communicate with the central locks. Would it matter if the vag-com is registered? BTW, i have a '96 with keyless.
    Oct 24 2006
    99 A4 1.8TQM, 04 Yamaha FZ1
    NC
    Re: B5 A4 Easter Eggs! Features not found in the owner's manual.
    Quote Originally Posted by burner799 View Post
    ^^Im 99.5+ and still can't do that. I am more interested in speed sensitive volume control but, I think its only 2000+
    No, you should be able to adjust the GALA settings. I have it on my 99 (pre-facelift). Instructions are in the manual.
    1999 A4 1.8TQMS Brilliant Black
    APR Stage III, APR race cat, APR exhaust, APR snub mount, Werks of Art clutch, V&S shifter, Forge 007 DV, Depo projectors w/ 5000k HID's, Goodyear Eagle LS2's on 17" B7 sports (summer), Dunlop Winter Sport M2's on 17" B6 sports (winter), stock sport suspension, AWE boost guage, Audi Sport rubber floor mats, smoke side markers
    Established Member Two Rings BeeFiveQuattro's Avatar
    Apr 05 2005
    2001.5 A420VTQCS / 5MT
    101/Mulholland
    Quote Originally Posted by AUD-A4 View Post
    i've also tryed the eq settings,didnt work for me either!!! :(
    It works for my '01 (hold down "5" and turn the symphany unit on):
    -IMO the best setting for non-bose is 13999931.
    Veteran Member Three Rings AUD-A4's Avatar
    Oct 26 2006
    2007 Subaru Wrx STI
    Central New Jersey
    Quote Originally Posted by BeeFiveQuattro View Post
    okay thanks,but you said you have the symphany,and i thought that the 98's came w/ the concert unit. would that make a difference??? ehh i'll try it anyways,i'llkeep you guys posted
    Its Better To Lead Than To Follow!!!!
    2007 WR Blue Subaru Sti
    mods- 3in.catless T/B exhaust,(Fujitsubo Super T1 axle/bac,InvidiaV2catless D/P)untuned, 18x8.5 gunmetal Work Emotion CR's wrapped in 235/40/18 General Exclaims',blacked out headlights,Chargespeed front lip,Tein S.Techs,Grimmspeed TGV Deleates,65mm APS cold air intake,3in Agency Power turbo inlet pipe, NGK step colder spark plugs,Cusco oil-catch can,APS dual vent bov,AEM methanol injection kit :)
    Veteran Member Four Rings white fish's Avatar
    Feb 21 2004
    05 allroad(old) 10 Q5 10 S4 13 S6
    T.O.
    got a couple question
    the alarm why would I want to turn up or down the sensitivity??
    and what The interior lights turn on like in an airplanes thing??
    Senior Member Three Rings Chop4Life's Avatar
    May 08 2005
    2001 A4QM
    Portugal
    With the car unlocked, best noticed at night, if u open the drivers door, the dome light under the dash that lights up the pedals/floor,carpet etc.. lights up, and the passengers light stays off. Opposite if u open the passenger side, the light turns on and with the drivers side shut, that light will be off.. FOUND OUT LAST WEEK lol
    http://tinypic.com/ao23w4.jpg
    2001 A4 1.8TQM
    Debadged, Strat Shortshifter w/Rob Knob II, RS4 Grill
    w/quattro badge and blacked out rings, M3 Spoiler, 6000k xenon kit.
    Veteran Member Four Rings superman_006's Avatar
    Jan 14 2007
    Porsche 996 C2
    WV
    Pull up on the door handle if under 40 degrees to activate the heated door locks, on front doors
    2015 Audi Q5 S-line 3.0T
    Veteran Member Four Rings SurferForever's Avatar
    Nov 28 2006
    01 A4 1.8TQM
    Warren, NJ
    Quote Originally Posted by Chop4Life View Post
    When i first noticed this i thought the passenger bulb was out and i had to pick up a new bulb to put in. Later that night i went to get something out of my glove box and then saw the driver side wasnt on and got really confused and thought that i just remembered the wrong bulb being out. then realized it when i went and opened the driver door to see what kind of bulb it was. What a useless feature this is . . .
    Natasha: 01 A4 2.0 T28/T04 || Silver (Fastest Color)
    034 Motor and Tranny Mounts | Full 3" exhaust with HFC | APR Snub | B&M Short Shifter | APR Boost Gage | RS4 Grill w/ Custom Matched Lowers | 8000k Headlights | 3000K Fogs | M3 Lip Spoiler | Reiger Roof Spoiler | Debadged | Clear Corner Mod | Independent Fogs | Dual Rear Fogs | Zimmerman Cross-Drilled Rotors | Mintex Pads | SS Braided Lines | 18X8 Black ASA AR1's
    Senior Member Three Rings Wilco's Avatar
    Dec 11 2006
    1998.5 B5 A4 2.8QM
    Tacoma, WA
    Huh? Heated door locks? What years have this and how do they work?
    BRAND SPANKIN' NEW: AudiWiki.net
    1998.5 Brilliant Black A4 2.8QM
    Jan 14 2007
    Porsche 996 C2
    WV
    First advailable in 1997 The All Weather package includes heated front seats, heated drivers door lock, outside heated mirrors and heated windshield washer nozzles.
    The heating element in the lock cylinderis activated by breifly pulling on the door handle. The heating element operates at outside temperatures below 41 F (+5 C) The element stays on for a predetermined period which is controlled automatically according to the outside temperature, but not longer than 50 seconds. It is not possible to extend this period by pulling the door handle continuously, but can be reactivated by pulling the door handle again
    Feb 26 2007
    98.5 Audi A4 2.8 quattro
    Oregon
    There is a little button on the drivers side between the front and rear doors..what does it do?
    Veteran Member Four Rings 4ringAR's Avatar
    Sep 18 2006
    Colorado
    Quote Originally Posted by alhal View Post
    it turns off the motion sensor inside car if you lock the car and have a kid/pet/etc in the car. (it is off when the little red light on button is on).
    2001 Audi ur-allroad, Frankenturbo'd, 6-Speed Convert: BUILD THREAD
    "Forget Tibet, free the left lane."
    Veteran Member Four Rings s vier's Avatar
    Dec 10 2006
    Midwest
    If.......when you need to get flatbedded, don't let the towtruck driver hook your car by the axels. Instead, pull off the foglight grills and show him the towhooks.
    Jan 14 2007
    Porsche 996 C2
    WV
    When you lock all your doors the trunk and fuel door lock too
    Veteran Member Three Rings Bic-Ball's Avatar
    Mar 29 2007
    Is the street.
    Long Island, New York
    For those people wondering about relocation the remote antenna I read about that thing too and I had the same problem. I figured it out and wrote a little DIY on the Fourtitude forums.
    http://forums.vwvortex.com/zerothread?id=3005879
    Registered Member Two Rings spud's Avatar
    Jan 18 2007
    Michigan
    No idea if this is in the manual... but anytime if you just turn off and then on the radio, it will turn on. Even if the key is out... even if doors are locked. I found this feature pretty cool.
    P.S. the radio will shut off when the battery gets to low. Found this out while waxing my car. It left plenty though for starting it up again. :)
    Also, thanks to those who posted the Vag-Com stuff... got my 1 click unlock done :).
    Jul 27 2004
    Quote Originally Posted by spud View Post
    I believe it just shuts itself off after an hour.... you sure it has to do with the juice remaining in your battery? That would be cool cause I dont know if mine would last an hour (with subs and all)... So I never leave it on that long
    Jan 18 2007
    Michigan
    Quote Originally Posted by Sk8Surfr View Post
    Ah, it could be timed too, didn't think of that. I just know that when mine did end up shutting off my lights were pretty dim when I turned them on, so I just figured it was the battery.
    Jul 27 2004
    Quote Originally Posted by bellofello View Post
    I'd love to know where this black box is as well.... mine looks like this. mine is an 01
    2000 B5 1.8QTM
    Dublin, CA
    Looking for info on how to crack a Symphony stereo in my '00. I bought a used one to replace my original, but I do not have an unlock code. Will a VAG-COM help here? I have access to one, but no codes to get the Bose to come off of safe mode.
    Sep 18 2006
    Colorado
    -If you roll up any passenger's window from the drivers door, while you are holding the button the light for that doors window switch will turn off.
    -When you turn the dome light on, everything that illuminates brightens. When you turn the dome light off, the illumination slowly darkens a bit.
    -*For Concert I* Pressing and holding FM2 while turning on the radio makes the radio show "GALA." By pressing FM2 you can scroll through some menus that does crazy stuff that I havent figured out like "NAV," "VOL," and some other things.
    -*For Concert I* Pressing and holding the button "2" while turning on the radio puts it into some other crazy GALA mode that I cant figure out.
