Results 1 to 7 of 7
    Buncha motorcycles
    Memphis, TN
    Motul RBF600 vs Motul 5.1
    I was fixing to order some RBF 600 but i had read one post on here awhile back that said it easily absorbed moisture and needed frequent flushing.. while shopping online one site selling 600 and 5.1 side by side said the rbf 600 was recommended only for racing because it easily absorbed moisture..
    anyhow any thoughts before i order?... i dont track it but everyone points to my fluid/air as my problems so i dont want to cheap out on $15 less for a fluid flush thats not as good.. i do drive pretty hard sometimes through the hills although that doesnt even compare to track conditions
    APR Stage 2/AWE Intake
    Mar 27 2005
    The Cold North
    Re: Motul RBF600 vs Motul 5.1
    RBF600 will require flushing more often. It is a great race fluid, but it does have a tendency to absorb more water and will nessitate bleeding more ofter.Then again most people that race bleed their brakes almost every time to the track. You should be fine with the Motul 5.1 and flush it every other year. You can also use the Pentosyn Super DOT fluid, it is a good high quality all around fluid.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    With RBF600, you'll need to flush it once a year. With the 5.1, you can flush it every other year like all other DOT 4 brake fluids.
    USP CLUB MEMBER #34
    Veteran Member Four Rings Ultrasport Steve's Avatar
    Feb 22 2004
    17 Audi A3, 10 Audi A3 HB 2.0T (son's car)
    Aptos, CA
    Quote Originally Posted by CyberPMG View Post
    Yeah..what he said. That being said..I am overdue for a good flushing.
    17 Audi A3 quattro
    Senior Member Two Rings CuStOm's Avatar
    Dec 08 2005
    Portland, OR
    I've used both on my race Ducati and can not tell a difference in brake feel or fade. The boiling point on the 5.1 is still higher than you'll ever see on your street car.
    USP CLUB MEMBER #666
    2004 USP 1.8T, K04, REVO, the list goes on.
    Feb 22 2004
    Aptos, CA
    Quote Originally Posted by CuStOm View Post
    Youve obviously not been at Willow Springs/Buttonwillow/Thunderhill when it is 105 degrees out..and your driving hard around a track in a heavy Audi.
    17 Audi A3 quattro
    Veteran Member Four Rings Elberoth's Avatar
    Feb 18 2004
    1990 Ferrari Testarossa
    Warsaw, Poland
    As an alternative, you can get Castrol SRF. It is even better than Motul RBF600. Beeing a race fluid, it also needs changing once a year.
    2021 Audi R8
    2012 Porsche Cayenne
    2010 Audi S5 - facelifted F & R (sold)
    2010 Audi Q5 2.0TDI facelifted F & R (sold)
    2002 Audi A4 1.8T Sportec K04 Stage II (sold | will be missed)
