Results 1 to 9 of 9
    Veteran Member Three Rings JWERNER24's Avatar
    Nov 08 2005
    1983 Porsche 944 (Track Toy), 1997 Toyota 4Runner (Offroad Toy)
    Central Oregon
    radio removal key stuck!!
    Is there a proper way of removing these other than just pulling them out? I cant seem to get one of them out...
    sounds dumb, but any help would be great. Im tired of driving around with a key in the radio!
    Sold: 2002 Ming Blue A4 3.0 MT6Q
    Current: 2001 Brilliant Black allroad 2.7tQ
    FOR SALE: 1983 Porsche 944 - PM for details!
    Orange County, CA
    yes, look on the side of the radio, you can push in a little button that releases the radio removal key. you have to push it in all the way though and the key will come out easily.
    B5 Parts For Sale
    Nov 08 2005
    Central Oregon
    Got it, thanks!
    Established Member Two Rings joebleu's Avatar
    Dec 11 2009
    Los Angeles, CA
    Hi Guys,
    Sorry for necro thread... but I can't get my radio keys out of my unit, and I can't find the "button" described here. My radio is just hanging out until I can get the keys out. Please help!
    2003 Audi A4 1.8T Quattro
    APR Stage 1+ | Genesis 380cc Injectors | EuroCode FMIC | RS4 Sway Bar | Neuspeed SS | DV710N
    Dec 11 2009
    Los Angeles, CA
    Well... I got them out... I pretty much bent the keys up from the locks. At least its working now!
    Jun 08 2007
    Orlando, Fl
    All you had to do was take the radio out and push on the springs to release the keys. Then you push the radio back into the console and it locks back into place.
    BetaAlphaTauMember #39 GTRS Powered/Revo Tuned
    Sep 10 2011
    None
    Quote Originally Posted by joebleu View Post
    Wow.
    Dec 11 2009
    Los Angeles, CA
    Quote Originally Posted by A4Dit View Post
    Yeah, I had the radio out and tried to push on the metal springs but they were already pressed all the way against the wall of the unit with the radio keys in; there was simply no more push to them but the keys were still locked in. I studied it for a while and it appears to be a very simple mechanisms but since this was a German-(over)engineered part, I thought that there may actually have been a button that I was completely missing so I figured I would check here first before applying brute force.
    I believe the cause of the problem was that the crappy eBay keys I bought were not cut very well and it was basically jammed. Since there have been others with this problem and general question of radio key operation, I have drawn a diagram to assist.
    1) Without the radio key inserted, the 4 metal springs are out and thus, the radio is locked into place.
    2) With the radio key in, the springs are retracted, freeing the radio and can be pulled out.
    3) Once the radio is out, the springs should still have some space to be pushed in further; this will push the pin past the key grove, thus freeing the key. This should be done BEFORE the radio is to be placed back.
    4) If your key is stuck inside the radio and the is no more pushed in the spring, you can remove the key by inserting a flat-head screwdriver underneath the key and push up; this will lift the key over the pin, allowing you to pull the key out.
    Active Member Two Rings Fullyscared's Avatar
    May 30 2013
    Fresno, CA
    I Wasn't very smart about this. I have a B5 S4 with a syphony I radio. I put my radio back in with the ebay keys still in. I can't pull the keys or the radio back out. I'm angry.
    Can anyone help me? or will i have to drive around with 4 keys in my f***ing radio?
