Results 1 to 13 of 13
    Forum Moderator Four Rings
    Apr 16 2005
    Pearl City, Hawaii
    Timing belt cost and time frame..
    Did a search and didnt really come up with much. Need a rough idea on how much it would cost to do timing and how long would it take. Don't want to fork up too much and I am kind of in a time constraint. TIA
    B5S4/A3S3RS3/Hawaii Forum Moderator - PM Comments/Concerns
    18 Daytona Gray Pearl S3
    00 Laser Red S4 (Sold )
    VAST Performance | BLOUCH | AWE | EvolutionRacewerks | Volk Racing | Vogtland | STaSIS/Alcon | JHM Motorsports | RS4 OEM
    Jan 01 2005
    MN l VT
    People say you should do it every 60k miles. Audi says 105k. I haven't done mine yet and Im at 92k. Im going to do it next summer cause Im away from home till then. I believe ECS sells a kit
    Veteran Member Three Rings DarkcydS4's Avatar
    Jun 13 2005
    e92 335xi FBO+Meth, 2014 BMW X3 M-Sport
    Madison, WI
    If you are paying to get it done.....it should take one day (full shop day) and you're looking at anywhere from $800-$1400 depending on where you go.
    _____________________________________________
    RETIRED: 2001.5 Audi S4 STG 2+ *SOLD*
    CURRENT: 2008 "Montego Blue" E92 BMW 335xi + 2007 "Raven Black" Suzuki GSX-R600
    Jun 13 2005
    Madison, WI
    if you're planning on doing it yourself and not familiar with the car...better set aside the weekend and like meddie says, ECS sells a kit.
    Account Terminated Four Rings
    2001 S4 GT28, 2001 S4 168K
    Long Island, NY
    i have complete timing belt tools for rent if interested so you cant go wrong with my tools. timing is set automatically by the locking bar and the locking pin all you have to do is put on the timing belt and your set. I will fedex the tool to you with a deposit for it and the deposit will be returned once i receive the tool back and i will also send complete instructions how to do your timing belt. If anyone is interested in doing their timing belt in NY please let me know i can do it for you along with anything else you need done to your car.
    Apr 16 2005
    Pearl City, Hawaii
    Damn too bad I'm not in NY
    Registered Member Two Rings James@Creative's Avatar
    Aug 24 2005
    San Diego, CA
    If any of you guys are in Southern Cal, we charge a very reasonable $875, for a full timebelt water pump job.
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    i thought TB was very hard, but as long as you dont get it off timing, everything else is easy. i have and 98 A4, nothing compared to 2.7T, but is just setting your mind that you can do it, and everything will be ok, thats what it did, and i saved myself the labor, which i spent on the S4 front bumper + paint.
    2001S4NY is really helpfull since he is offering the tools.
    Good luck if you DIY, if not good luck as well with your bank acct loosing, at least, arround $800 bucks, which you can spend in something else.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Veteran Member Four Rings HighDesertAudi's Avatar
    Mar 09 2005
    NorCal
    I say DIY if you have any knowledge of cars. I did my A4 in 5 hours start to finish. Even at $80/hr that would still only be $400, I dont know how shops get away with charging double for a job they could do faster than me anyways. The stealership wanted $1100 just for labor.
    Previous Audi's
    1999 Audi A4 1.8T Quattro 5spd Laser Red
    2000 Audi S4 6spd Nogaro
    1990 Coupe Quattro 5spd Lago Blue
    2000 Audi S4 6spd Laser Red
    2004 Audi S4 6spd Dolphin Gray
    2004 Audi A4 6spd Brilliant Black
    Veteran Member Three Rings IamEzraM's Avatar
    Jul 21 2005
    2001.5 Audi S4 Santorin
    Bedford/MA
    I bought the Truly Ultimate TB kit from Jeremy at Matrix for around 300, and had a local shop put it on for about 300. I called Audi and they wanted $1500, ha
    My car is fast
    Sep 11 2004
    2000 s4
    los angeles
    Agreed. An honest, competent reputable shop will prolly charge around 300-400 in labor. I paid about 300 for the TB job.
    Then again some shops have more overhead than others.
    Active Member Two Rings PA::S4new's Avatar
    Nov 16 2006
    PA
    I think I paid about $1200 for the full timing belt service (waterpump, thermostat, tensioner/pulley/roller) as well as cam and cam cover seals, cam tensioner seals, valve cover gaskets, and my snub mount. Seems about in line with what others are saying and the cam tensioner seals definitely added a few dollars to the bill. Having just bought the car, I wasn't too confident in my DIY abilities so paying for it was the only way to go for me. I had the tensioner fail about 2 weeks after having the service - but luckily the shop hooked me on labor. My only recommendation would be to get the complete/ultimate kit (like ECS caries) if you can swing it.
    Good Luck!
    Registered Member Two Rings DroO587's Avatar
    Feb 19 2005
    2000 s4
    Braintree, MA
    Just did mines at 95k, Cost of parts was about 300$ with g12 coolant. from ecs tuning, I did Tb, waterpump, thermosta, accesory belt. Took about 8hrs for me. I've done one on my 1.8t a4... remember to let the car idle till normal temps, check for coolant leaks, make sure the fans work, when you put that new pump with gasket, put on some ahesive, to get the gasket to stick on the pump evenly then put it on. I suggest to have the water pump and many other parts toque aswell.
    2000 s4/ Rieger front bumper/ Rs4 grill/ 19" AT Italia riva's/ UUC VM1 cat-back/ Giac X chip/ Autometer boost gauge/ H&R Coilovers/ Turbo xs Bovs/ Rieger roof spoiler/Euro plate/suede shift boot/Phillips 6000k
    SOLD
