Results 1 to 1 of 1
    Junior Member Two Rings
    May 16 2024
    Scottsdale AZ
    Question LED DRL code 02895
    Hey guys!
    Took my car to a self serv car wash today, and seemed to have messed up my drivers side (LHS) headlight.
    After the wash, there was some fog in the headlight, which cleared up on the drive home. What didn't clean itself up is that the car is now throwing 02895 and 01493. After the drive home, the DRL was working and so was the turn signal, but the dash was showing the DRL error. Powered off and back on the car and the codes didnt come back and the headlights were functioning as normal.
    A few hours later, turned the car on and it threw the codes. This time the DRL was not illuminate and the turn signal works, but flashes off tempo from the others when hazards are on. The actual LED headlight is still working.
    OBD eleven shows both codes:
    02895 "Supply for Left LED Parking Lamp/DRL Module"
    01493 "Left front turn signal bulb"
    Car is a 2016 A6 3.0t with LED headlights for reference.
    Anyone have any experience with this? Is there a DRL module I can buy and swap back out to fix this or am I replacing an entire LED headlight?
    Any help would be greatly appreciated!
    Edit: Just looked at headlight to see where the DRL module is, the water in the lamp did not clear up. Humid outside now and the headlamp has fog/humidity inside
