This is from what I am aware the first time a plastic 3d printed intake manifold has been driven in the world on the road for the b5. I know Modsport in Portugal is also doing one but have only seen them trying to idle their car and it's a lot taller.
Info:
1. I was under a bit of time pressure but the manifold held 7psi fine, with some air leaks from the injector bosses splitting and only being able to run 7psi because I hooked up the diverter valves wrong and forgot to plug in the IAT sensor. Injector bosses will be beefed up.
2. This plastic is ASA and really at its temperature limit, but still runnable for the short term and mainly to get fitment right with it needing some mild touch-ups.
3. This is a Blake Beadle etspec stage 1 tune on this car but looking at doing further testing and design this thing to hold 40-50psi. I've managed to test a printed cube 5mm thick that held 75psi.
4. A new printing method called bricklayers is now available and this will drastically increase pressure holding and sealing capabilities IMO.
5. I will at this stage most likely use CF polycarbonate for the final product but have CF polypropylene that I will try first. If that's not enough we will move onto CF nylon.
6. I've made adapters to funnel the 2.8 runners to 2.7 for this test.
There is way more testing to do and will take this to the 17psi next week when I get back from work.
If there is anyone wanting to help will testing I the future let me know.
Sent from my SM-A546E using Audizine Forum mobile app
