Results 1 to 7 of 7
Thread: 275/40R18?
    Junior Member One Ring
    Apr 17 2024
    Florida
    275/40R18?
    Hey guys!
    I was just wondering if anyone is running 275/40R18 on their S4. If so, do you have any tips for making them fit well? I am in the market for a new set of wheels and tires, and if anyone is running this tire size, some pics of the setup would be greatly appreciated.
    Feb 20 2023
    Northbrook, IL
    Unsure they will fit? Front calipers might rub. I haven't seen anyone running 18's... I have 19x9.5 +25 offset and have 275/35 Michelin's. They fit but needed all the camber I could get once modestly lowered.
    CURRENT: Quantum Grey 2019 S5 Sportback Prestige, Black Optics, S Sport Package
    Neuspeed RSe102's, 034 Trans Mount Insert & tranny mount upgrade, ABT HAS, 034 intake and inlet, 034 Stage 1 ECU/ Stage 2 TCU tune, 034 front strut brace, 034 subframe and diff mounts, 034 RSB, 034 RSB & end links, iSweep IS2000 pads, Neuspeed braided SS brake lines, Wagner Comp intercooler, more to come...
    GONE BUT NOT FORGOTTEN: 2017 VW GTI SE, highly modded and tracked.
    Established Member Two Rings BaggedB9S4's Avatar
    Nov 16 2020
    Arizona
    That size tire is too tall, wont work. I have seen one guy use 275/30/19, which is shorter than factory. Requires a really high offset wheel
    Feb 20 2023
    Northbrook, IL
    Quote Originally Posted by BaggedB9S4 View Post
    Sorry, I am running 265/35/19's...
    Senior Member Two Rings Jetta03's Avatar
    Jan 29 2020
    Not sure about the width, but 18's should fit over the calipers no problem. I use some old 18" RS4 replica wheels as winters and they fit fine.
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    https://www.wheel-size.com/calc/
    Try this tire/wheel visualisation aid assuming you know most of the tire/wheel parameters your are dealing with.
    Current:
    2017 B9 A4 Technik, 2.0T, 6 spd manual, S-Line, quattro with Ultra
    2008 B7 A4 Avant, 2.0T, 6MTQS, S-Line, Special Edition
    Past: - 2005 B6 A4 3.0 V6 6MTQS, 1998 B5 A4 2.8 V6 5MTQS
    Feb 04 2025
    Westfield, IN
    I'm running 245/40/R18 OEM wheels and tires and they fit fine over the calipers. I plan on upgrading my wheels in a few year and would also like to run a wider setup, the 40 series sidewall is great for ride quality which I appreciate and won't give up, so I'm sticking with 18s. I don't think I'd go wider than 255 though, 275s seem crazy wide lol.
