I have a 2012 a6 and have been having some parking aid issues. The code shown is,
"B107A14 - Supply voltage for park assist sensor: Open circuit/short circuit to ground".
If any sensor was dead it typically says front left censor open, etc. but this doesn't. Ive tried countless troubleshooting options. The sensor harnesses (both front and back) read 12v when NO sensors are plugged in.
once I plug a sensor in (regardless of which socket I use) the whole system reads 2v to any sensor plugin socket. Ex. plugging in a sensor up front (only one) would make the rear socket read 2v (was 12v before plugging a sensor in) and this was the case with any combination of plugging in and testing a different sockets voltage.
Ive tried this method with COUNTLESS amount of sensors. I tried with every single existing OEM sensor I had plugged in one by one and they all shut the system down to 2v from 12v. This code cannot be reset, it instantly comes back as permanent even when all sensors are plugged in. Obviously parking aid doesn't work, + backup camera doesn't get triggered. Backup camera only works for a split second once I attempt to reset the code. What could this be?? any ideas? Please let me know if any more info is needed!
