Audizine's Facebook Fan Page
+ Reply to Thread
Results 1 to 6 of 6
    Site Moderator Four Rings AvanTTix's Avatar
    B6 A4 1.8T Avant, MKI TT 1.8T 225hp Roadster
    San Francisco, CA
    B6 A4/S4 - Symphony II to RNS-E (OEM DVD based Navigation)
    This write-up documents the process of upgrading from Symphony II to an RNS-E whether it's a Euro unit (8E0 035 192 C & D) or a US unit (8E0 035 192 E & F).
    for a complete list of all the differences btw a Euro unit and a NA unit, please check this thread on NavPlus... be aware that the price is significantly different btw a Euro unit (US$1,500) vs. a US unit ($2,000+), however apparently it is possible to modify a Euro unit to operate like a US unit (see the following NavPlus thread).
    please note that you will need a patch NA map DVD to work with the Euro RNS-E...
    i cannot guaranty these instructions may be applicable to those upgrading from a manufactory installed RNS-D (partial or full)...
    although such upgrade might appear daunting, it is absolutely not. no electronic skills are required to perform this upgrade, no mechanical skills either. the whole process is really straight forward.
    the actual shape of the Symphony II and RNS-E (and RNS-D) is the same, thus the RNS-E fits right in the opening of the Symphony II w/o the need for any kind of modifications... that's indeed another story of you've got a Symphony I...
    further to an RNS-E unit the following parts are needed:
    - RNS-E adaptor:
    this adaptor is designed for a non-Bose system and is ready for the CD changer... make sure you order the adaptor that meets your needs.
    - Diversity and Radio antennas adaptor:
    be aware there's another style of adaptors out there, but i would recommend not getting this one... if you do, you'll have to find a way to secure the diversity antenna in its connector, and the Radio antenna adaptor will need to be jammed in to stay plugged in...
    i had that adaptor at first, and decided to get the dual one, which fits perfectly... so imo, avoid the one pictured below...
    - GPS antenna:
    here's a couple of places where you can source these from:
    . AudiZine classifieds
    . NavPlus classifieds
    . Euro-Parts in the States - run by BayrischerS4 from NavPlus
    . Kufatec in Germany - beware of shipping costs...
    - OEM Manuals:
    these can be obtained from Audi of America and Audi Canada Technical Literature Ordering Center, and at US$5 per publication, these are quite cheap imo...
    (...continued...)
    San Francisco, CA
    B6 A4/S4 - Symphony II to RNS-E (OEM DVD based Navigation) [Part II]
    Now on to the actual process of installing the RNS-E unit...
    i believe the pics are self explanatory, especially since i've annotated all of them... i also apologise in advance to all the purists out there if i have not used the proper terminology!!!...
    - Symphony II Connections:
    - Fuse Box Cover:
    (...continued...)
    San Francisco, CA
    B6 A4/S4 - Symphony II to RNS-E (OEM DVD based Navigation) [Part III]
    - Knee Bolster - Removing:
    - Knee Bolster - Re-installing
    San Francisco, CA
    B6 A4/S4 - Symphony II to RNS-E (OEM DVD based Navigation) [Part IV]
    - RNS-E Unit Connections:
    - RNS-E Connector Adaptor:
    - Diversity Antenna:
    - Diversity and Radio Antennas Adaptor:
    (...continued...)
    San Francisco, CA
    B6 A4/S4 - Symphony II to RNS-E (OEM DVD based Navigation) [Part V]
    - GPS Antenna:
    - GPS Antenna Location:
    - RNS-E Connections:
    - CD Changer Connections:
    wire the CD Changer harness (part number: 8E0 051 592) following the instructions provided w/ the harness w/ the only exception that the wires should be plugged in directly the Connector #1, do not use the connectors provided w/ the harness... then as far as the ground wire goes follow the instructions below...
    finally the next step is to VAG the car so that it acknowledges the RNS-E unit... accessing "Module 17 - Instrument Cluster" isn't necessary if you've already had an RNS-D installed and programmed before...
    now time to put your car back together, so just follow the above instructions in the reverse order...
    Stéph - Moderator
    MY2003 B6 A4 1.8T Avant
    : DenimBlue||Ebony||5-Speed MT||Quattro||Premium Package||Sport Package
    MY2002 MKI TT 1.8T Roadster: BrilliantWhite||RedAmber w/ Baseball Optic||6-Speed MT||Quattro||Premium Package||Audio Package
    San Francisco, CA
    Alright, finally got around to re-linking all the pictures...
    Stéph - Moderator
+ Reply to Thread
    © 2001-2010 Audizine, Audizine.com, and Driverzines.com
