Greddy III Turbo Timer installation guide in foglight/cupholder
Preface: After installation of my GIAC installed 2 years ago, I have always wanted to install a TT to help with proper cooling for my turbo. After some research of this TT install, I found several guides/write up from AudiWorld tech as well as fellow AW posts; although the current guide in the AW tech gave a pretty good direction on the install, but picking through the ignition wires as well as possibly various problems with windows / locks after the install seems like a big task for a electrical noob like me to tackle this. However, with the help with Chad's guide and Kitch's post about an different approach, I have found that installing a TT way easier than what it seemed.
Supplies/Tools Needed:
* Greddy Turbo Timer III (~$80.00)
* Wrench or ratchet / socket (for battery terminals)
* Wire Cutters
* Friction Tape (it’s highly advisable to use friction tape…I’ll explain later. BTW - this is very similar to the tape which is used on hockey sticks…you can buy it from any Sporting Goods store)
* 14ga. Red Wire (You can buy both Red and Black wires, the wire is mainly for extending the wire length from the TT)
* Wire taps (2-4; depends if you want to tap everything or just slice)
* Inline fuse holder (mini-weld)
Approximate time: 1hr to 3hr
Prep work on TT:
1) Lay out your TT kit (things you need)
TT turbo timer & BIG wiring harness w/ 4 wires.
* RED: Power
* BLUE: E-brake
* GREEN: Ignition
* BLACK: Grounded
2) Cut up the un-needed wire (BLUE) all the way to the harness. This is for the E-brake setup, which will not be covered in this guide.
3) Use the 14ga. wires to extend the wire that comes off the harness about 2-3 feet longer (Red and Green), the BLACK ground wire is quite long, so you don’t need to extend this one. I use Red wire to extend TT’s RED and the cut out blue wire to extend TT’s GREEN.
Finding place for TT:
4) I choose to put it in my fog light switch location since I like to have a cup holder. Many people choose to put in the TT in replace of the cup holder. Pop the trim off around your cup holder using a small flathead screwdriver.
5) There are two metal clips that hold the the fog light / ESP switch assembly in place - pry them off & slide out the whole assembly; unplug the the foglight switch ont he back. *** I have since then relocated my switch to the drive side ***
6) Drop the driver's side knee bolster. Depending on where you are installing the TT, you might need to pull out the instrument cluster, direction can be found at Audi World tech. I do not see the need of taking out the cluster for the location I chose.
7) Now, you should be able to fish the Greddy harness from the cup holder locale to under the steering column. Connect the harness to the TT and drop it to underneath the column.
8) Wrap the TT a few times w/ friction tape - or electrical tape - & push it into the cup holder / fog light switches recess. It should fit nicely Reinstall the trim piece. Looks good, huh?
9) Back under the dash, cut off the Molex plug on the TT harness. You'll have three wires - RED, GREEN, & BLACK (BLUE was cut). Now we are ready to connect the TT to the car.
Wire connections:
1) Since you are working with electrical now, it’s a good idea to disconnect the (-) terminal of your battery to avoid any fireworks.
3) Pop the fuse cover panel and Remove the bolts that hold the fuse box to that metal bracket - pull it down)
4) Find the tiny BLACK w/BLUE wire coming out the back of position #6 - cut it... yeah - CUT IT.
5) Remove fuse from position#6 (put it into the inline fuse holder). Connect the wire that you just cut from fuse 6 (central locking) to a fuse holder; I put an 5 amp fuse into the holder. Then connect the other end of fuse holder to the 75x post next to the 30.
6) Now the other wires, the TT’s GREEN goes to the VAG connector that is underneath the knee bolster. Look for the a tiny Black/Blue wire on VAG connector and use a wire tap to connect to the TT GREEN wire (blue in the picture since that’s what I use to extend the wire).
7) The TT RED wire goes to the 30 post. I just made a loop with the wire and attach there.
Final connection check
8) Find a nice place to ground the TT using the pre-terminated BLACK wire. I used the bolt that secures the fuse box.
9) Re-connect (-) battery terminal & make sure everything is powered up & the TT is singing it's stupid little song. Hate it - it's OK, you can change it in the setting.
10) Clean up your wiring w/ a few zip ties &/or friction tape, put everything back together, & set-up the TT as per directions
- Samuel
*PLEASE NOTE: Postings made within this Forum are not open for public debate as the rest of those on Audizine. Only additional information regarding the subject matter at hand may be submitted for addition. Please direct all other comments or questions to either the Post's author or an AZ Admin. Please see the sticky in this Forum for the full listing of Forum Rules & Guidelines. - AZ Admin
